Went to my local Autozone and ordered a filter for my automatic tranny. Deep pan or shallow pan? Look for 20 bolts he says. Find out later that both have 20 bolts. Said give me the fluid and I'll check further. They said use Mercon 5. My owners manual said to use straight Mercon. Their catalog said use Mercon 5. Does anyone sell straight Mercon any more?, I can't find it.
Went to Checker next. They said 4x4 is deep pan and 2wd is shallow. Sounds reasonable!!! Why didn't Autozone know that? Got the fluid?? Nope Bought the filter 10 bucs less than autozone????? Got Mercon left from last tranny service, don't want to drain converter, and need more fluid. Still haven't done anything. Not sure how many miles I will have before this situation is solved. Can you mix mercon with any other fluid? Some say multi application or service fluid. I give up!!!!!
Can they be mixed safetly? And what is the general feeling for using Lucas Tranny Treatment ? I used it last time I changed fluid and filter. Is it worth the $10>
Thanks
Good point about the additives. I just thought it would give some extra benefits not formulated in the standard fluid.....Never claimed to be very bright!!!! :-)
Thanks
