Sponsored by: Real Truck
tow command problem
Old Aug 24, 2008 | 10:17 PM
richsoucie's Avatar
richsoucie
tow command problem
Ok heres the deal when i start the truck the controller goes through its diagnostic test turns on flashes the lights then turns off. but when i plug my trailer in it doesnt come on at all any idea whats going on. and yes the trailer does have electric brakes and they are hooked up. also if i pull the manual overide the controller turns on with a red trailer on it and the brakes on the trailer do not lock up. is there a relay somewhere that i should check or what. truck is a 06 f-250
Old Aug 24, 2008 | 10:51 PM
ReAX's Avatar
ReAX
I would start with seeing what the trailer plug sees. Make sure the correct pin has voltage when the brakes are applied. Then make sure that the trailer has a good ground and the brakes are pinned the same as the truck's plug. I've come across several trailers that were wired wrong.
The signal out from the brake controller is variable, so a relay would not be effective in delivering adjustable voltage.
Old Aug 24, 2008 | 10:59 PM
WildWildWest's Avatar
WildWildWest
Your controller isn't recognizing a trailer attached if you get a red trailer sign when you push the manual brake activator. It should show a solid green trailer when you have connection. Problem could be in the trucks plug or wiring or in the trailer plug. Either way the controller doesn't see a trailer attached if you get the red trailer light. You should try hooking up another trailer that has electric brakes and see if the controller reacts properly just to make sure where to start looking.
Old Aug 25, 2008 | 11:21 AM
Lou Braun's Avatar
Lou Braun
Fixing a trailer connection problem can be a lesson in frustration control. The best way is to find if the problem is with the truck or with the trailer by testing them seperately.
The plastic cover on the 7-pin trailer connection has a wiring pin-out diagtram on it. Try checking each output with a voltmeter and verify that each output works.
Next check the trailer end. I use a 12-volt battery and connect the battery negative side to the ground connection in the trailer's 7-pin connection. Then test each trailer pin to see if trailer lights, signals and brakes work.
If all else fails, Ford dealers have a test plug that connects to your truck's trailer connection. This tests the Tow Command system. With luck you can find the problem without visiting the dealer.
Usually it is a problem with trailer wiring. Either a shorted connection or poor ground.
Lou Braun
Old Aug 25, 2008 | 06:18 PM
richsoucie's Avatar
richsoucie
update: there is 12v at the 7 pin on the truck and when i pull the manual overide with the trailer plugged in there is 12v at the trailers junction box on the wires that go to the brakes but the tbc still does not turn on when the trailer is plugged in
Old Aug 25, 2008 | 08:04 PM
richsoucie's Avatar
richsoucie
anyone know if the cardone master cylinder from advance auto parts comes with the sensors installed on it the part number for advance is 103222 or does anyone know what the ford part number is for the master cylinder with the brake pressure transducer is.
Old Aug 25, 2008 | 08:42 PM
pstrokejoe's Avatar
pstrokejoe
Is there 12v all the way back at the brakes with the override on? Sounds like a ground problem.
Old Aug 25, 2008 | 08:56 PM
richsoucie's Avatar
richsoucie
didnt get back that far didnt feel like takin the wheel off also the trailer does not use the frame as common ground everything that uses electric has a ground wire running to it from the junction box on the which gets its ground from the 7 pin on the truck. the ground is good at the junction box
Old Aug 29, 2008 | 10:09 AM
richsoucie's Avatar
richsoucie
just checked voltage at the axle and there is 12 volts at the wiring that goes into the brakes on the axle i checked i didnt bother checking the other axle cause i know that at least one axle is wired properly and the controller is still not turning on with the trailer pluged in. also when i pull the manual slide it says check trailer
Old Aug 29, 2008 | 10:19 AM
FTX's Avatar
FTX
What year is your truck? Some of the early O5 Tow Command units had problems and needed to be replaced with updated version. If I recall correctly the build date on the Tow Command Units that had problems were March of 04 or earlier. FYI, this is the build date for the unit NOT the truck.
Old Aug 29, 2008 | 10:22 AM
SOB Racing's Avatar
SOB Racing
Do not just figure its the truck with the problem it could be the wiring on the trailer. if thats not it, check all the fuses and relays associated with the tow command, there are seperate fuses and relays for lights, brakes, battery charge, ect...
Old Aug 29, 2008 | 10:29 AM
richsoucie's Avatar
richsoucie
its an 06 fuses good relays good wiring at the brakes on the trailer good has 12 v where the wires come out of the axle and go into the drum
Old Aug 29, 2008 | 10:48 AM
SOB Racing's Avatar
SOB Racing
I had a similar problem and was the hot wire from the truck to the trailer battery.. Is the battery at full charge?
Old Aug 29, 2008 | 10:52 AM
richsoucie's Avatar
richsoucie
i dont think the battery is even hooked up
Old Aug 29, 2008 | 12:38 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
How do you expect the emergency break-away to set the trailer brakes if you become disconnected if the trailer battery is NOT working/hooked up? BTW, do NOT test the breakaway switch with the trailer/truck cord plugged in....
