Modular V10 (6.8l)
Headers, where to buy?
Old Sep 16, 2008 | 10:06 AM
Scottay's Avatar
Scottay
Originally Posted by krewat
How did they crack? Did you do any muddin'?
Mine are a year and a half old and still holding together quite nicely...
When you installed the Ebay headers, what did you use........studs or bolts? And how are they (headers and fasteners) holding up to normal use and weather? Had my studs and manifolds replaced 3 years (+/-) ago by the dealer (under Fords ESP) and are already due to be replaced again, this time by me, and I figure if I am going that far I may as well go with headers. I already have the Banks "cat-back" system, however I cannot justify the cost of the Banks headers..
Old Sep 16, 2008 | 01:15 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
With the headers I used, there were too many places where the tubes would be interfering with studs, so I used bolts.
I didn't use the ones they supplied, they were way too short.
I went out and found grade-8 zinc-plated (galvanized) bolts, used anti-sieze, and no problems so far. I measured the required length by using a depth gauge (the pointer that sticks out of a dial caliper) to measure the depth of the hole, added the thickness of the gasket, and the header flange, and came up with a length. Then added a lock washer and a stainless flat washer, and subtracted another 1/8" or so.
Even then, I had to use a somewhat shorter bolt in one or two places (but not as short as the supplied bolts).
