bad idle
Old Jun 29, 2001 | 01:21 PM
Redstallion4x4's Avatar
Redstallion4x4
bad idle
hello everyone, i hope someone can help me out here. i have a 92 f-150, with the 5.0 liter and a 5speed. its also a 4x4, but dont think that will matter. when i got the truck the throttle seemed to stick a little when you would step on the clutch. it slowly got worse until it would idle at 2800 or so and there was no way to get it to kick down. we had it tested and it said that it was the idle senor value. i put one of those in and it still does it. i found out that if that valve is unpluged it doesnt idle high. but now the check engine light is on. i have cleaned almost every connection under the hood with no look, any help anyone can give me i would appreciate. i thank you all in advance.
Old Jun 29, 2001 | 08:15 PM
thelonerangerxlt's Avatar
thelonerangerxlt
bad idle
Red, did you disconnect the battery for a few minutes after changing the IAC? This resets the computer.
Old Jun 29, 2001 | 08:19 PM
Redstallion4x4
bad idle
hey thanks for that info, i havent tried that, i am going to go try that now, thanks alot, i will let you know what happens.
Old Jun 29, 2001 | 08:35 PM
thelonerangerxlt
bad idle
1983F1503004x4
May 23, 2013 12:24 PM
dlfracer28
Mar 18, 2010 06:51 AM
texas zeke
Modular V8 (4.6L, 5.4L)
Aug 31, 2008 11:27 PM
tcbofade
53
Jun 7, 2006 02:24 PM
00Ranger4x4
1983 - 2012 Ranger & B-Series
Sep 12, 2002 03:10 PM
