Help!:)
Old Jun 26, 2001 | 09:12 PM
oleblue70's Avatar
oleblue70
Help!:)
Hi,
Ok,
I have a '79 F150 that is popping the brake light fuse and the radio fuse at the same time!
The radio is the factory harness so it isn't a hack job hangin over the brake pedal,ect.
I took the fuse block screws out and flipped it over,and (brakes,radio are beside eachother)and all looks well inside.Nothing touching till they get into the main harness of wires.
I usaully figure these things out but not this time!
Anybody got any ideas?If so thanks
...blue
1970 F250 Sport Custom 4x4.351W,DuraSpark,N.P.435,Dana24,Dana diffs,4.10:1's,36x9.00 CordovonPower Kings,Blue/white.---oleblue---
1966 F-250 4x2,390,4spd,Custom Cab,Blue/white---bessie---
1979 F-150 Ranger 4x2,302,C4,cold A/C,thumpin' stereo,brown/tan---tany---
Old Jun 29, 2001 | 08:35 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Help!:)
Blue, the only thing that comes to mind, is maybe a corroded tail light bulb socket. Electrical Gremlins are strange animals, and you obviously have a dead short somewhere to blow both fuses.
With the key off, check the radio side of the fuse with an ohmmeter to a ground. If you show an open, then short is in tail light circuit. If you show a complete circuit, then it's in the radio side. Hope this helps. Don
Old Jun 30, 2001 | 06:54 PM
treefort's Avatar
treefort
Help!:)
