differential fluid?
Old Aug 24, 2008 | 10:38 AM
crestfallinman's Avatar
crestfallinman
differential fluid?
my differential gasket seems to be failing and i need to find out what differential oil to use until i can get the time to change the gasket
which oil do i use?
Old Aug 24, 2008 | 01:15 PM
quaddriver's Avatar
quaddriver
75w-something gear oil works. If you have LS add a few oz of friction modifier ifn its empty.
If this is stock, virgin, unmolested truck there may be no gasket at all - just a bead of RTV that dried up
Old Aug 24, 2008 | 01:38 PM
Lazy K's Avatar
Lazy K
Good advice. Also check to ensure the breather tube is not blocked.
Old Aug 24, 2008 | 09:07 PM
crestfallinman
thanks i will be puttin more fluid in there and checkin the rear end on wendesday
