trans question...
Old Aug 23, 2008 | 11:22 PM
bigsteve1969's Avatar
bigsteve1969
trans question...
ok goin down the highway today and when i was at 65 i just tapped the brake and my rpms went from about 1800 to 2k.... i was like what? it was almost like it downshifted is this the tq locking up or somethin? oh and at 70mph i was runnin about 2k rpm thats bout normal true...
Old Aug 23, 2008 | 11:27 PM
willeo6709's Avatar
willeo6709
2k at 70 is pretty much what the 7.3 excursion runs, 3.73 gears..... My guess is that rpm spiked a bit when the converter unlocked. The closest parrallel I can draw is manual trans related... assume you did not have a clutch shutoff switch on the cruise of a manual... disengage the clutch, engine load goes down, rpm goes up without a throttle change. Something mey be slower at reacting to engine load changes on cruise or it may be a sign of a problem...I am sure those wiser than I will chime in shortly.
Old Aug 23, 2008 | 11:30 PM
bigsteve1969
the cruise was not on and its automatic
Old Aug 24, 2008 | 07:53 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It was the torque converter unlocking. It's working as designed, nothing is wrong.
Old Aug 24, 2008 | 08:21 AM
zx250's Avatar
zx250
Of the next Riffraff East
Before my DP-Tuner, mine did exactly the same thing. Nothing wrong, just torque converter unlocking, like already posted. Mark is the guru and if he says it's ok, then it's ok.
Old Aug 24, 2008 | 09:36 AM
bigsteve1969
kool deal its kinda cool oh and i got 22mpg coming back from alabama yesterday and thats with a bad exhuast pressure sensor (gotta get that fixed tho)
