Overheating
Old Aug 23, 2008 | 08:42 PM
MIKE1646's Avatar
MIKE1646
Overheating
I have a 1990 f150 with the 302 engine 72k miles.
It has a new radiator, water pump, wires, plugs, water hoses, new fan and clutch and it has a 5 speed.
The truck is overheating at idle when the a/c is running.
I don't know where to look anymore, any ideas?
Old Aug 24, 2008 | 03:45 PM
Holmesuser01's Avatar
Holmesuser01
Do you have a fan shroud? Is it the original fan?
You've replaced everything that I can think of that would cause it to overheat... Have you checked the water temp with something besides the factory guage?
What about the thermostat?
Old Aug 25, 2008 | 01:45 PM
MIKE1646's Avatar
MIKE1646
Factory stock, only new parts. Temperature went up to 230 with different gauge.
Old Aug 25, 2008 | 07:05 PM
stuart1's Avatar
stuart1
um
I don't see any mention of a thermostat.
Old Aug 30, 2008 | 10:26 AM
fasthauler's Avatar
fasthauler
You say it is overheating at idle. Is it running cooler while running at higher rpms? If so then you probably have an airflow problem. Mine will start getting hot while sitting in lines at drive thru's, traffic lights, etc. I have to kick it into neutral and bring the rpms up while in these situations to keep the temps down. I am considering an electric fan, possibly in the front of the condenser to push through while idling. Maybe that would solve your problem as well.
kevinred410
18
Aug 4, 2011 12:36 PM
edonop
Jul 31, 2011 02:35 PM
bkeese
Sep 5, 2006 10:34 AM
ed2hess
19
Aug 12, 2006 02:31 PM
FourthFordTruck
4 Cylinder Engines
May 25, 2004 09:04 AM
