air intakes & headers
Nothing at Thorley.
Hedman:
Hedman Hedders - Hedman
But I can't find "50 state legal" for yours.
Hooker, better luck:
http://www.holley.com/types/Truck%20...Compatible.asp
Google search "headers" and then find the mfg site and put in your info.
As for intake, you are efi, correct? So you're looking for a cold air intake?
Or???
As to the door: Are you taking the door off or door and hinges? You have a new door?
Support the door with something strong enough to hold the weight and wide enough to lower the door onto horizontally. If you are buy yourself, brace it up. Undo the bottom bolts first. Leave one in to hold it from rotating on you. Do the tops, pull the last one and ease it away and lower it.
I did one on a Mustang, it didn't kill me.
Good luck.
The stock air intake on the EFI's is a cai...
The aftermarket "cai's" actually just allow alot more air flow.. But its the warmer engine bay air...
So cold air intake isnt exactly correct...
Just a FYI for you guys..
