Electrical Wizards Needed - Inquire Within
Old Jul 26, 2001 | 04:34 PM
aerocolorado's Avatar
aerocolorado
How does the reset valve switch on a RABS unit function?
The troubleshooting procedure for a flash 4 code for the RABS valve begins with a continuity check between the reset valve switch connector pin and the body of the RABS valve unit.(Which should be over 10K ohms). Both the original suspected unit and the boneyard replacement show up as 0.0 ohms resistance. Obviously to have continuity, the reset valve must ordinarily be grounded internally to the valve body. A literature description about the functioning of the RABS valve states the reset switch works when there are unequal pressures between master cylinder and rear brake lines BY GROUNDING which interrupts the logic circuit of the computer modeum. This would seem to imply the normal state would be "open" (non-grounded). I have a hard time believing the Ford factory manual would have you test for something that can't be done. On the other hand, both units are registering zero which tends to confirm the "open" position findings. Can anyone explain this discrepancy?
Old Jul 27, 2001 | 08:18 AM
dsc's Avatar
dsc
Runfox
20
Oct 14, 2020 11:55 AM
tom-rad
1997 - 2003 F150
Apr 22, 2012 07:17 AM
jay_s5
Nov 23, 2004 04:49 PM
