Parking light fried!!!!
Thank you for any help,
Ben
Ben
I only improved on it. On my 73 the RH front parking light wire went direct to the headlight switch while the LH front wire went to the rear of the truck and then to the headlight switch. It was actually spliced to all the rear parking lights. Well it used to be that way, now it is tapped off the RH front wire. And the rear lights have their own wire from the headlight switch.
I beleive that all 73-79's are like this and maybe even 67-72's. Of course if you have one of those "new-fangled" 80's or 90's models I can't really help you
Sparky
I think your problem may actually be a bad ground or frayed wire since it only affected the single lamp. What I would do to test the lamp are as follows:
1. Disconnect the wires to the housing. Check your continuity between the power lead(s) and the lamp housing. If there is, your insert is bad andhas shorted to ground and needs replaced.
2. If no continiuty, replace the bulb and run a jumper wire from the battery to the power lead. If it works, you have a break in the power lead. If not, attach another jumper wire to the frame or other ground leaving the jumper connected. If this works, you have a bad ground in the socket or the mounting of the housing.
These tests isolate the lamp from the rest of the circuit. If the lamp itself works, you now can work yourself back to the original power source, switch or whatever to find the break.
Let us know what you find out.
Krosati
Visit my homepage at ClubFTE
http://www.clubfte.com/users/krosati/
