A Shifty Question
Old Aug 23, 2008 | 03:40 PM
dennisb56's Avatar
dennisb56
A Shifty Question
Happy Summer to everyone, I've been having a good one using my truck as much as I can. Even with gas prices its been great to have it on the road. In a month I'll start the body shop course at the local vo-tech and hopefully next spring it will be time for paint.
My question for today is, I have a 3 on the tree shifter and wonder how hard it would be to change to a floor shifter. Why I what to do this is even with all the rubber bushings replaced and everything greased that you can once in a while things jam up, its not too bad until it happens going into 3rd merging onto the highway then its an issue, especially when the wife is with you on the way to a cruise night. Anyway any ideas on converting it to a floor shift would be appreciated.
Thanks.
Old Aug 23, 2008 | 04:51 PM
Old F1's Avatar
Old F1
Here are two, buy the best one (Hurst) you can afford, the cheap ones are crap.
You will have to cut some kind of hole in your floor pan.
Mr. Gasket 3-SPEED MANUAL FLOOR SHIFT CONVERSION KIT : JC Whitney: Auto Parts & Accessories
Hurst 5010002 3 Speed Shifter Indy SSA Universal
Old Aug 23, 2008 | 07:35 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Personally I would change to a top-shift tranny, on a 56 it's a pretty easy job and you have your choice of 3, 4, or 5-sp's (and some 4-sp's and the 5-sp's are OD to boot).
Old Aug 23, 2008 | 07:44 PM
Julies Cool F1's Avatar
Julies Cool F1
It's not to hard to switch.
But, I had a 3spd overdrive on my 55 and it did the same thing occassionally. I found out that all I needed to do was adjust the rod length (by loosening the locking nuts on each side of the shift arm) and (I'm not quite sure how to describe this) but adjust them so they were both farther out from neutral than before. In other words the gear you are shifting into takes a little more travel of the Column shift arm/rod/arm/shift fork to engage the gear.
Good luck,
J!
Old Aug 23, 2008 | 09:59 PM
driver96er's Avatar
driver96er
If I was to this switch hurst is the best for the money
Mercury Bluz
Jul 29, 2008 08:21 PM
J.O.S.
Nov 16, 2006 11:56 PM
irocknrol2
1983 - 2012 Ranger & B-Series
Oct 17, 2006 10:20 PM
sancochojoe
Jun 30, 2006 10:26 AM
fredjeep
Ford vs The Competition
Jul 5, 2004 12:22 AM
