It knows the speed you desire when you set it. Unlike mechanical pedals that move up and down in cruise control, ours does not. The PCM does not need an electrical signal from the pedal to signal more or less fuel. It does it via electronics based on the speed of the vehicle and load from sensors. It is old tech now but still good stuff. Fly by wire like an F-16.
Unfortunately, fly by wire can cause problems when the pedal assembly goes on the blink. This rascal can be hard to diagnose.
Good write-up Cody.
So when you turn the cruise on and set it, the PCM must "let go" of the APP reading and instead rely on a signal from the VSS? Or does it "remember" the signal from the APP and lock on it, so to speak? Yes I'm retarded I know, just curious and trying to learn so I can be 1/2 as smart as some of you on here.
All I can say is WOW!!!!!!! That was very informative, easy to read and understand, and some great information for folks like myself that don't really understand what all these items do. Definitely repping ya!!
Yes. Check it yourself if you like. First thing I noticed about my truck. Once you hit cruise, the pedal is deactivated and returns to idle if you let off. If you command more than is required to cruise the PCM responds and accelerates. In a gasser, the pedal moves up and down with grades as there is a throttle body with a plate. We do not have this. IOW, despite not having a throttle body/plate assembly, we can accelerate beyond the cruise simply by inputing more throttle than the cruise calls for. Just play with it and you will see what I am talking about.
I didnt read a damn word of the thing, (no insult to you cleatus), but the first thing that came to my mind when i scrolled and scrolled and scrolled and saw more words, was Ernest. From the feedback it looks like i should set aside the afternoon tomorrow to read it.
Holy schnikees!! This thing BLEW UP way out of proportion. I think maybe I'll put a disclaimer on the next one letting everyone know that I don't expect any form of praise.....I'm just a hard-working guy that was waiting for something to come into the shop.
Cody... very well written. Easy to follow and understand. Very concise, especially given the breadth of issues you were covering. Kudos and reps to you, my man!
Excellent write up!! Reps sent.
Kris get off your lazy duff and read it. I am sure you will have something to critique about it, and that is what he asked for.
Good write-up Cody.
Using the cruise can actually HELP diagnose TPS issues.
Cody, what Pete said. Usually I have to get psyched up to read something "technical" but I started reading and didn't quit till the end. That is getting printed out and put in my "tech manual" for my F350.
Edit: umm..... do I have to pay a license or tech fee to print it out?
