Emissions System Light
P0506 was the code number and it is called "Idle Control System - RPM Low"
Is this a sensor? Im guessing something is dirty or faulty. Has this happened to anyone before?
Cory
IAC system RPM lower than expected
DETECTION CONDITION
• The PCM compares the actual idle speed with the target idle speed when the engine is running. If the actual idle speed is lower than the targeted by 100 rpm for 14 s, the PCM determines that the IAC system RPM is lower than expected.
Diagnostic support note
• This is a continuous monitor (CCM).
• The MIL illuminates if the PCM detects the above malfunction condition in two consecutive drive cycles or in one drive cycle while the DTC for the same malfunction has been stored in the PCM.
• PENDING CODE is available if the PCM detects the above malfunction condition during the first drive cycle.
• FREEZE FRAME DATA is available.
• The DTC is stored in the PCM memory.
POSSIBLE CAUSE
• IAC valve malfunction
• A/C cut-off control malfunction
• Generator control system malfunction
• Intake-air line clogged
- Clogged air cleaner
- Clogged throttle body
• Purge solenoid valve malfunction
• IAT sensor malfunction
• ECT sensor malfunction
• CKP sensor malfunction
• Insufficient compression
- Engine oil malfunction
- Oil pressure decrease
- Oil pump malfunction
- Oil pump control malfunction
- Engine malfunction
• Fuel line pressure malfunction
• PCM malfunction
Diagnostic procedure
STEP
INSPECTION
ACTION
1 VERIFY FREEZE FRAME DATA HAS BEEN RECORDED
• Has FREEZE FRAME DATA been recorded? Yes Go to the next step.
No Record the FREEZE FRAME DATA on the repair order, then go to the next step.
2 VERIFY RELATED REPAIR INFORMATION AVAILABILITY
• Verify related Service Information availability.
• Is any related repair Information available? Yes Perform repair or diagnosis according to the available repair information.
• If the vehicle is not repaired, go to the next step.
No Go to the next step.
3 VERIFY RELATED PENDING CODE OR STORED DTC
• Turn the ignition switch off, then to the ON position (Engine off).
• Verify the related PENDING CODE or stored DTCs.
• Are other DTCs present? Yes Go to the applicable DTC inspection.
(See DTC TABLE [ZJ, Z6].)
4 INSPECT IAC VALVE
• Inspect the IAC valve.
(See IDLE AIR CONTROL (IAC) VALVE INSPECTION [ZJ, Z6].)
• Is there any malfunction? Yes Repair IAC valve, then go to Step 19.
(See IDLE AIR CONTROL (IAC) VALVE REMOVAL/INSTALLATION [ZJ, Z6].)
5 INSPECT A/C MAGNETIC CLUTCH OPERATION
Note
• The following test should be performed for A/C. Go to the next step for vehicles without A/C.
• Turn the A/C switch off.
• Is magnetic clutch still on? Yes Go to the "NO.24 A/C IS ALWAYS ON OR A/C COMPRESSOR RUNS CONTINUOUSLY.".
(See NO.24 A/C IS ALWAYS ON OR A/C COMPRESSOR RUNS CONTINUOUSLY [ZJ, Z6].)
6 INSPECT GENERATOR CONTROL SYSTEM OPERATION
• Apply the electrical load during idle.
• Is the engine speed increased? Yes Go to the next step.
No Repair or replace the wiring harness for a possible short to power supply, then go to Step 19.
7 INSPECT AIR CLEANER ELEMENT
• Remove the air cleaner element with the engine running.
• Is the engine speed increased? Yes Clean or replace the air cleaner element, then go to Step 18.
(See INTAKE-AIR SYSTEM REMOVAL/INSTALLATION [ZJ, Z6].)
8 INSPECT THROTTLE BODY PASSAGE
• Remove the throttle body.
• Is throttle body clogged? Yes Clean the throttle body passage or replace the throttle body, then go to Step 19.
9 INSPECT PURGE SOLENOID VALVE
• Inspect the purge solenoid valve.
(See PURGE SOLENOID VALVE INSPECTION [ZJ, Z6, LF].)
• Is there any malfunction? Yes Replace the purge solenoid valve, then go to Step 19.
(See PURGE SOLENOID VALVE REMOVAL/INSTALLATION [ZJ, Z6].)
10 INSPECT IAT SENSOR
• Inspect the IAT sensor.
(See INTAKE AIR TEMPERATURE (IAT) SENSOR INSPECTION [ZJ, Z6].)
• Is there any malfunction? Yes Replace the MAF/IAT sensor, then go to Step 19.
(See MASS AIR FLOW (MAF)/INTAKE AIR TEMPERATURE (IAT) SENSOR REMOVAL/INSTALLATION [ZJ, Z6].)
11 INSPECT ECT SENSOR
• Inspect the ECT sensor.
(See ENGINE COOLANT TEMPERATURE (ECT) SENSOR INSPECTION [ZJ, Z6].)
• Is there any malfunction? Yes Replace the ECT sensor, then go to Step 19.
(See ENGINE COOLANT TEMPERATURE (ECT) SENSOR REMOVAL/INSTALLATION [ZJ, Z6].)
12 INSPECT CKP SENSOR
• Inspect the CKP sensor.
(See CRANKSHAFT POSITION (CKP) SENSOR INSPECTION [ZJ, Z6].)
• Is there any malfunction? Yes Replace the CKP sensor, then go to Step 19.
(See CRANKSHAFT POSITION (CKP) SENSOR REMOVAL/INSTALLATION [ZJ, Z6].)
13 INSPECT ENGINE COMPRESSION
• Inspect the engine compression.
(See COMPRESSION INSPECTION [ZJ, Z6].)
• Is there any malfunction? Yes Go to the next step.
No Go to Step 16.
14 INSPECT OIL PUMP
• Inspect the oil pump.
(See OIL PUMP INSPECTION [ZJ, Z6].)
• Is there any malfunction? Yes Repair or replace the malfunctioning part according to the inspection results.
Overhaul or replace the engine.
Then go to Step 19.
15 INSPECT ENGINE OIL CONDITION
• Inspect the engine oil condition.
• Is the engine oil condition normal? Yes Go to the next step.
No Replace the engine oil.
Inspect the ECT sensor and related wiring harnesses.
Then go to Step 19.
16 INSPECT OIL PRESSURE
• Inspect the oil pressure.
(See OIL PRESSURE INSPECTION [ZJ, Z6].)
Then go to Step 19.
17 INSPECT OIL PASSAGE
• Inspect the oil passage.
• Is there any malfunction? Yes Inspect for leakage and/or clogging in oil passage of engine and repair if necessary.
Then go to Step 19.
No Overhaul or replace the engine.
Then go to the next step.
18 INSPECT FUEL LINE PRESSURE
• Perform the "FUEL LINE PRESSURE INSPECTION".
(See FUEL LINE PRESSURE INSPECTION [ZJ, Z6, LF].)
• Is there any malfunction? Yes Replace the fuel pump unit, then go to the next step.
(See FUEL PUMP UNIT REMOVAL/INSTALLATION [ZJ, Z6, LF].)
19 VERIFY TROUBLESHOOTING OF DTC P0506 COMPLETED
• Make sure to reconnect all disconnected connectors.
• Clear the DTC from the PCM memory using the WDS or equivalent.
• Start the engine.
• Is the PENDING CODE for this DTC present? Yes Replace the PCM, then go to the next step.
(See PCM REMOVAL/INSTALLATION [ZJ, Z6].)
20 VERIFY AFTER REPAIR PROCEDURE
• Perform the "AFTER REPAIR PROCEDURE".
(See AFTER REPAIR PROCEDURE [ZJ, Z6].)
• Are any DTCs present? Yes Go to the applicable DTC inspection.
No DTC troubleshooting completed.
Very interesting.
Cory
Cory
