Transmission OE4D
Old Mar 31, 2001 | 07:20 PM
trevorw's Avatar
trevorw
Transmission OE4D
Hello,my 91 F350 diesel flares up between 2nd and 3rd when pushing it hard,it otherwise shifts flawlessly when driving normally.Should i be concerned,or just leave it until it gets worse.Any help would be apprciated.
Thanks,TrevorW
Old Apr 2, 2001 | 07:49 PM
otto's Avatar
otto
Transmission OE4D
I would atleast change the fluid and filter
Old Aug 17, 2001 | 04:46 PM
jayr's Avatar
jayr
Transmission OE4D
you need to check the diesel section on this one. My E4OD went belly up after just two days of ownership. After replacing the trans, 4 months later the torque-conv burned up and back to the shop i went. Always leave the truck out of over-drive untill you are 55 MPH or higher. The whole time i was having this problem 2nd to 3rd shifting was way slow. I am still not impressed with the shifting now, even with the new torque-conv in place. If you solve this problem please let me know.
Old Aug 29, 2001 | 05:36 PM
Ryans460's Avatar
Ryans460
Transmission OE4D
The E4OD in the trucks(especially diesels) has always had problems. You will either have to get it rebuilt or put a new one in. I would do it before it gets real bad and leaves you stuck, because if you let it go, it will.
If it's shiny, it must be loud!
1994 F-250 7.5L 4x4
Old Aug 29, 2001 | 09:53 PM
sparky's Avatar
sparky
Transmission OE4D
roadhouse1979
Sep 30, 2013 06:19 PM
Kirbys73F100
Offroad & 4x4
Oct 9, 2012 12:49 PM
neer150
401, 477, & 534 SD Engines
27
Jul 13, 2005 01:28 PM
xpres
New York Chapter
Jun 8, 2004 05:01 PM
Motorcraftsman
Jan 13, 2003 04:59 AM
