System isn't charging for some reason :(
Old Aug 24, 2001 | 02:15 PM
kmdigital's Avatar
kmdigital
I have an 89 E150 Ford van, (300 straight 6) that stranded me along the road last night because the charging system quit working. I assume the alternator probably failed, but is there anything else that I should be looking at instead/also? I haven't had time to look at it yet, but is there a separate voltage regulator, or is it built into the alternator? Any suggestions/hints would be greatly appreciated. thanks.
Old Aug 29, 2001 | 07:51 PM
sparky's Avatar
sparky
Sorry missed the post, you probably have it fixed by now but there should be a separate voltage regulator. Most parts places will test both the regulator and alternator for no charge, so you don't replace good parts.
Sparky
Old Aug 30, 2001 | 10:14 AM
lanero's Avatar
lanero
My '89 F250 did the same thing a while back. Turned out to be worn out brushes. $7 from the parts store and about an hour to install. It's been fine ever since.
And if I remember right, the regulater is attached to the back of the alt., but it can be replaced seperatly.
Roger Lane
Test Analyst
Sr. Automated Test Engineer
IBP, Inc.
Old Aug 30, 2001 | 01:31 PM
sparky's Avatar
sparky
Old Aug 31, 2001 | 12:20 PM
kmdigital's Avatar
kmdigital
Thanks guys. I ended up replacing the Alternator, because the brushes had worn so much that there was a deep groove worn in the one armator surface. By the way, I replaced it with an alternator for the 302, because it was less expensive and had a better warranty. I just had to rotate the front housing 180 degrees and change the pulleys.
