Flashing light
Old Aug 21, 2008 | 11:07 PM
Vinford's Avatar
Vinford
Flashing light
My son just bought a 08 F-150.
Nice truck , but theres a flashing red light on the top of the dash in front of the driver?
What is it Im to lazy to read the manual right now.
Thanks.
Old Aug 21, 2008 | 11:11 PM
Capbyrd's Avatar
Capbyrd
anti theft light.
Old Aug 21, 2008 | 11:16 PM
Vinford's Avatar
Vinford
I thought it might be something like that.
Whats it do?
Just sit there and blink or does it actually do something?
Old Aug 21, 2008 | 11:21 PM
Capbyrd's Avatar
Capbyrd
Well, thats also the sensor for the auto headlights but as far as antitheft, i dunno.
Old Aug 22, 2008 | 05:56 AM
Deluxe05's Avatar
Deluxe05
The flashing LED on the top, left-hand side of the dash is the SecuriLock anti-theft indicator. And, yes, its sole purpose in life is to flash as a visual theft deterrent.
The autolamp sensor is the small'ish nub located on the top, dead center of the dash.
Per pages 131-2 of the 2008 Owners Guide (3rd printing):
SECURILOCK(TM) PASSIVE ANTI-THEFT SYSTEM
SecuriLock(TM) passive anti-theft system is an engine immobilization system. This system is designed to help prevent the engine from being started unless a coded key programmed to your vehicle is used. The use of the wrong type of coded key may lead to a “no-start” condition.
Your vehicle comes with two coded keys; additional coded keys may be purchased from your authorized dealer. The authorized dealer can program your spare keys to your vehicle or you can program the keys yourself. Refer to Programming spare keys for instructions on how to program the coded key.
Note: The SecuriLock(TM) passive anti-theft system is not compatible with non-Ford aftermarket remote start systems. Use of these systems may result in vehicle starting problems and a loss of security protection.
Note: Large metallic objects, electronic devices that are used to purchase gasoline or similar items, or a second coded key on the same key chain may cause vehicle starting issues. You need to prevent these objects from touching the coded key while starting the engine. These objects will not cause damage to the coded key, but may cause a momentary issue if they are too close to the key when starting the engine. If a problem occurs, turn the ignition off, remove all objects on the key chain away from the coded key and restart the engine.
Anti-theft indicator
The anti-theft indicator is located on top of the instrument panel.
  • When the ignition is in the 1 (OFF/LOCK) position, the indicator will flash once every 2 seconds to indicate the SecuriLock(TM) system is functioning as a theft deterrent.
  • When the ignition is in the 3 (ON) position, the indicator will glow for 3 seconds to indicate normal system functionality.
If a problem occurs with the SecuriLock(TM) system, the indicator will flash rapidly or glow steadily when the ignition is in the 3 (ON) position. If this occurs, the vehicle should be taken to an authorized dealer for service.
Old Aug 23, 2008 | 02:50 PM
wildcard30's Avatar
wildcard30
Ever watch BattleStar Galactica? It's a mini Cylon...
ctruf1504x4
Apr 26, 2012 08:50 PM
underDAWG
22
Jun 24, 2006 10:46 PM
JoeLindaMiller
Oct 24, 2004 11:10 PM
marragtop
Oct 22, 2002 09:40 PM
stevieray
Sep 18, 2001 05:36 AM
