94' 300 M5OD Running Rough
Old Aug 21, 2008 | 09:53 PM
1994XL4X4's Avatar
1994XL4X4
My 94' F-150 300 M5OD. After sitting for more than about 5 minutes will start up fine run fine for about 30 seconds, it will then hesitate, jerk, shudder, for about 1 1/2 minutes, then it will run fine. It just started to do this tonight. It has had a slightly hunting idle for about 2 years. Within the last 15,000 miles it has received a new coil, plugs-ford, cap/rotor, IAC motor, Newer plastic vacuum canister, most rubber vacuum lines, PCV, Air Filter, and Fuel Filter. Also a couple of times last winter when it was very cold-The Check engine Light came on with the code of EGR Low Flow detected. I'm looking for ideas to check out tomorrow.
Old Aug 22, 2008 | 08:01 AM
Lazy K's Avatar
Lazy K
I would suggest you pull the EGR valve and clean it and the ports, clear the codes and see if there is any improvement.
