gas tank question
Old Aug 21, 2008 | 06:28 PM
justinfown1's Avatar
justinfown1
gas tank question
I live in 29 palms, ca ( the desert ) where it gets very hot. I filled up my tank last night and came back from the rifle range today to find i had gas running down the side of my truck from the gas cap. I have a 63 f250 4x4 flairside behind the seat gas tank. anyone else had this problem or know how I can resolve this issue? would like to find a solution before i tear into the truck and repaint it.... thanks!
Old Aug 21, 2008 | 06:53 PM
billy12360's Avatar
billy12360
dont fill the tank so full or maybe loosen the filler cap so that the preasure can come out, or the sending unit could be loosend but then you are releasing gas vapors[the really flamable stuff] into your cab..
Old Aug 21, 2008 | 06:57 PM
daveengelson's Avatar
daveengelson
Believe it's the nature of the beast with these 61-66 Ford trucks, at least with my 65 f100, fuel tends to drip from the cap particularly on hot days, I try to remember not to fill over max of 13-15 gals. Also check the condition of the fuel cap gasket, make sure it's making a good seal. Recently purchased a locking gas cap, now recall why I threw the last one away, have not found one that seals worth a damn.
Old Aug 21, 2008 | 08:43 PM
Sam_Fear's Avatar
Sam_Fear
I found out about the expansion of hot gasoline while sitting in my truck studying in between classes - smoking a cigarette! "Huh....something smells like gas....oh S***!" Didn't smoke in my truck after that (I've quit now.)
I always fill up at the start of my drive. That way I'm sure to use up a gallon or so.
Old Aug 22, 2008 | 01:08 AM
iiizman's Avatar
iiizman
I had the same problem and just didn't fill it up all the way anymore. I won't have the same problem when I am done. I am moving gas tank to the frame rails.
SEMPER FI
Old Aug 22, 2008 | 07:14 AM
banjopicker66's Avatar
banjopicker66
These trucks were not designed with seal-proof systems like today's vehicles. They vent through the cap seal.
There is space for an expansion-like chamber at the top of the tank, if you look closely. The fill tube is below the top a bit.
When the fuel gets warm it expands, much more so than water. Then the air in the upper pocket of the tank expands, and you have pressure pushing fuel up the spout.
Are you parking with the tuck leaning down a bit on the driver's side?
The best fix is to park on a level surface - or better yet, park with the spout up higher than the tank. That is, with the truck leaning down slightly to the passenger side.
This will allow air rather than liquid fuel to escape under expansion pressure.
If you park with the spout leaning down on the driver's side, the pressure will push air instead of fuel out.
Old Aug 22, 2008 | 02:53 PM
85e150's Avatar
85e150
Our '58 F600 in-cab tank did the same thing. Takes the door weather strip with it eventually, not to mention it's a bit tough on the paint.
Old Aug 22, 2008 | 04:25 PM
customcab66's Avatar
customcab66
I drilled a small hole in the back of my gas cap it seems to work good for venting the tank but sucks when you put it into a good right hand corner it spits a small amount of fuel out of it but not bad.
Old Aug 22, 2008 | 04:35 PM
jowilker's Avatar
jowilker
As other have noted, don't fill your truck up unless you are going to drive out 3 or more gallons of gas. Park it drivers side high like John said, you can always drive up on the curb to make that happen. The only time that I fill my truck up is when I am driving a 50 mile trip or gas is real cheap where I have stopped.
You will soon learn what your truck likes. Another thing don't fill the radiator up to the neck, leave it a couple inches down for expansion. Fill it to the top and it will burp it out.
John
Old Aug 22, 2008 | 09:20 PM
justinfown1
thanks guys!
Old Aug 23, 2008 | 07:51 PM
IsoGrifo's Avatar
IsoGrifo
had that problem one day, but it was because i filled up and forgot to tighten the gas cap, lol. Is this my truck or everyones truck where the tabs on the cap don't quite fit in the hole? well it'll keep the cap on and gas flies out in hard right turns, which I did a lot of.
Old Aug 24, 2008 | 09:12 PM
ras4434's Avatar
ras4434
It helps to be smarter thant he gas cap......which I apparently am not. I got tired of the gas dripping out and fading the paint. I moved the tank and now have that problem solved. I was somewhat motivated after recieving a $2500.00 ticket (not a typo) for "placing an offensive material on the highway". Good thing the local judge had a bumpside that did the same thing , especially in Oregon where you cant pump your owm gas. Life is good.
Old Aug 25, 2008 | 03:16 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
All these in-cab fuel tanks from 1956 thru 1969 use a vented gas cap.
They are not the non vented type used on some models with evaporative emission beginning in 1970.
The one thing that causes confusion and then peeps use the wrong gas cap is...the vented and non vented gas caps look identical in outside appearance.
Look at the backside of the cap to see the difference. As original: One has a hole in the center (vented), one does not (non vented).
B6TZ-9030-A .. Gas Cap-Use with In-Cab Tank-Vented (Motorcraft FC23)
Fits: All 1956/69's & 1970/77's without evaporative emission.
coonhunter
Mar 22, 2016 01:00 PM
muscletruck
Mar 3, 2009 06:24 PM
goose the redneck
Dec 26, 2007 05:42 PM
kaycie83
1983 - 2012 Ranger & B-Series
Nov 19, 2002 04:49 PM
candymankim
Feb 13, 2002 07:39 AM
