Sponsored by: Real Truck
Speedometer not working until 60 MPH
Old Aug 21, 2008 | 11:50 AM
johndeeretech86's Avatar
johndeeretech86
Question Speedometer not working until 60 MPH
When driving below 60 MPH i have no speedometer, and the ABS light is on all time. Once i reach what i beleive is 60 MPH speedometer works, but ABS light is still on. Just curious what my problem could be. Thanks
Old Aug 21, 2008 | 12:30 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It could be the vehicle speed sensor (VSS.) It's on top of the rear diff. It is magnetic and can collect steel filings from the diff. This will interfere with the signal. The sensor can also fail, which is not uncommon. It's about a $20 part and take one bolt and two minutes to change.
Old Aug 21, 2008 | 02:32 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE. I think Mark has this nailed down. Let us know if that is the problem. You can also get the sensor at NAPA, they call it the ABS sensor. Good luck.
Old Aug 23, 2008 | 07:06 AM
johndeeretech86
Works great now thanks for the help.
Old Aug 23, 2008 | 11:01 AM
SpringerPop's Avatar
SpringerPop
If you have an auto trans, I'll bet it shifts a lot better now, too!
Pop
