Line-X or Rhino Liner?
Which is the better liner for our trucks? I've checked prices around here and they're pretty close so that don't matter. My dad's got a Rhino in his truck and it works great but it's pretty faded after two years and just don't look as sharp as some Line-x's I've seen. What are ya'lls thoughts on whos better? Any problems with either one? Which one is tougher? Normal use only nothing really bad like loaded 55 gallon drums everyday but I will throw an engine in there once in a while.
I have Line-X in mine and love it. I've had it for 4 years and it looks like brand new. I went with Line-X over Rhino because I was told that if I ever had any issues with it, cracks, coming apart, etc, I could go to ANY Line-X dealer to get it fixed, whereas with a Rhino, you have to go back to the dealer that sprayed it in.
If you want it for looks then Line-X, especially the Line-X Xtra.
If you don't want anything to slide around in the bed then go for the Rhino.
Both are pretty dang tough.
I had Rhino in my 99, and it was faded pretty bad. I really liked how I could throw stuff back there and not tie it down though. When I got my 07 I took it and got Line-X Xtra sprayed in the bed, over the rails, on the toolbox, and on my DeeZee bed rial covers. It looks awesome, and really protects the bed, but stuff slides around real easy if you don't tie it down. I solved that by going out and buying a rubber bed mat from my local Farm & Fleet for $50. Now I have the best of both worlds.
http://s181.photobucket.com/albums/x...%20Oct%202007/
I have had both. I currently have the Line-X X-tra in my 2008, and this is the only drawback I have found with the Line-X. The color definitely seems to hold up better to the Rhino. A rubber mat seems to help quite a bit with the sliding issue.
There have been many of these thresds over the years and Line-X always gets the nod. Here is the bottom line:
If you are going to actually use the truck to haul stuff, get Rhino. If you have a pretty boy truck that will not be used for anything but looking good, get Line-X.
