Offroad & 4x4
Worth it?
Old Aug 20, 2008 | 04:04 PM
F250REBEL's Avatar
F250REBEL
Worth it?
I have been looking for an older ford just too take wheeling and beat on and i find something i might be interested in and was wondering your guys opinion. Its a 1990 fullsize bronco with a 460 swap with less than 40k and a C6 with 2 k on rebuild. It has a d44 with new shafts and 4.11 gears up front and a 9 inch,detroit locker and 4.11's. Its sitting on 9 inches of suspension lift and running 40 inch ground hawgs. The body is in decent enoguh condition for what im going to use it for. and he wants 3500 for it just curious what you guys though?
Old Aug 20, 2008 | 04:17 PM
oneofakind97's Avatar
oneofakind97
i say buy it. you sure its not 6" susp, 3" body? SAS up front? either way, i say pick it up. sounds like a real good deal to me.
Old Aug 20, 2008 | 05:55 PM
F250REBEL's Avatar
F250REBEL
Nope its all suspension it didnt have the blocks inbetween the body it was leaf springs in the rear and coils up front, what about the axles they seem a little small for 40's
Old Aug 20, 2008 | 05:58 PM
F250REBEL's Avatar
F250REBEL
and yeah it has a high pinion dana 44 up front, i wouldnt buy somethin without a solid axle up front i have my problems with the ttb on my truck and if i was still gonna wheel that itd be swapped out for a Dana 60
Old Aug 20, 2008 | 06:02 PM
ibleedblue1385's Avatar
ibleedblue1385
offer him $2500-3000
Old Aug 20, 2008 | 06:50 PM
straightsix4x4's Avatar
straightsix4x4
buy it, toss some 36s on it, then the gearing and axle strength would be about right, would be quite a machine
Old Aug 20, 2008 | 08:49 PM
75F350's Avatar
75F350
If it has 40 inch Denman ground hawgs, then it already has 36's (only slightly larger).
Denmans were a little exadurated when they sized them.
Most vehicles that can withstand 36 inch tires will have no problems with larger ground hawgs.
Vehicle sounds abou right if it is affordable,,,,,go for it. Always tryt o get a better deal, but you would have at least that much invested if you tried to build it yourself.
Old Aug 20, 2008 | 09:19 PM
F250REBEL's Avatar
F250REBEL
yeah it doesnt seem to bad im going to take a better lookat it and drive it tommorw after work, well i have about 6,000 saved up that i was going to use for my bronco build but he is pretty close to what i had already planned for my build, besides the d 44 and 9". I would have went with Dana 60s but figure those can be added after i break the old ones
Old Aug 20, 2008 | 11:38 PM
Tre-E_Ford's Avatar
Tre-E_Ford
sounds like a good deal, pics or it never happened
Old Aug 21, 2008 | 09:23 AM
1978fordf250's Avatar
1978fordf250
sounds good to me!
Old Aug 21, 2008 | 09:50 AM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
I would def, test drive it, make sure no death wobles, make sure 4wd engages, and works. Stuff like that, i think 3500 is a lil much though. I would go 3k cash.
As refernce i was gunna buy nick's bronco for 4k, (quadzjr) But unfortunatly bad timing came up and i spent all that money at the dr.
Old Aug 21, 2008 | 03:36 PM
F250REBEL's Avatar
F250REBEL
I went and took a better lookat it and drove it today... the frame seems to be straight as can be and only has minor surface rust. The body has some tiny dents and some scratchs, but i will most likely add to those if purchased. I took it for a little drive and that engine will toss you back in your seat with no problems even with the wrong gearing for the tires!!! It drove pretty decent for the 40" tires, wrong gears and all that lift.
I will hopefully be picking it up this monday if everything goes according to planned
Old Aug 21, 2008 | 04:25 PM
ibleedblue1385
dont forget to post up some pics!!!!!!
Old Aug 21, 2008 | 04:55 PM
Truckin4life
yup pics or it didnt happen!
Bftford
Dec 1, 2013 01:43 PM
Dan92
30
May 16, 2012 07:44 AM
masterguns2003
Dec 21, 2006 08:33 PM
ssKable
Aug 1, 2003 04:24 PM
