Hub Grease
Old Aug 20, 2008 | 03:48 PM
King0581's Avatar
King0581
Hub Grease
You guys that are pulling the ABS sensor and greasing the hub bearings threw that hole, what kind of grease are yall using?
Old Aug 21, 2008 | 07:08 PM
King0581's Avatar
King0581
Bump. Anybody?
Old Aug 21, 2008 | 08:10 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Whatever is in the grease gun at the time. Anything rated as a high temp bearing grease will work.
Old Aug 21, 2008 | 08:15 PM
King0581's Avatar
King0581
Thanks. just wanted to be sure before I did it this weekend.
Old Aug 21, 2008 | 08:52 PM
big poppa's Avatar
big poppa
Anybody got any pics of this procedure, want to do it to???
Old Aug 21, 2008 | 09:18 PM
TxFordGuy's Avatar
TxFordGuy
is there any certain amount to get in there? few squirts from grease gun? what intervals are you guys doing this?
Old Aug 22, 2008 | 06:09 AM
King0581's Avatar
King0581
Mike, not that I'm awhere of. If I think about it I'll take some this weekend and post them. I can do more stuff like that now that I have some HIGH SPEED internet. Anyways there was athread floating around about the fitting that was being made to put in in place of the ABS sensor. Dont know if you caught it, but you just gotta pull the calipers and drums to get to the ABS sensor and remove the little bolt that holds it in out and shoot some grease in the hole. I plan to put a good amount in mine at least once a year if not more.
Old Aug 22, 2008 | 10:38 AM
big poppa's Avatar
big poppa
Thats cool, i remember a thread posted 2 or 3 weeks ago, i'll search for it.. Thanks FOR THE QUICK INFO....
Old Aug 22, 2008 | 04:27 PM
SpringerPop's Avatar
SpringerPop
I'm using a CAT chassis lube.
CAT p/n 1P-0808
It's a blue-green multi-purpose lithium-complex base.
Pop
