Sponsored by: Auxito
Autodown window not working
Old Aug 19, 2008 | 10:27 PM
Troy77+79's Avatar
Troy77+79
Hi Guys, I just bought a 2001 F150 Supercab truck. The autodown feature on the driver's window doesn't seem to be working. When I press the button down and release it, the window stops immediately and I hear a click under the dash? Both windows work fine otherwise. Any ideas?
Old Aug 19, 2008 | 11:41 PM
chevma-67's Avatar
chevma-67
Check your relay in the fuse panel under the dash it should be the 2nd from the bottom on the left side of the panel.also when my auto down works I have to hold it a bit then release.other cars its just a touch and they go down dont know why our fords are not like that.good luck
Old Aug 20, 2008 | 07:25 AM
Troy77+79's Avatar
Troy77+79
Yeah, I've tried holding the button down until the window is over half way down, and it still just stops when released. I'll check the relay though. What's the best way to test it? Thanks.
Old Aug 20, 2008 | 08:15 AM
chevma-67's Avatar
chevma-67
Just swap the very bottom relay with the 2nd from the bottom as a test they are both the same I think.That will let you know if its good or bad.
Old Aug 20, 2008 | 07:07 PM
Troy77+79's Avatar
Troy77+79
I swapped relays 4 & 5, but there was no change. Still does the same thing. What else might it be?
Old Aug 20, 2008 | 07:49 PM
fire240's Avatar
fire240
Could be you switch.
Old Aug 21, 2008 | 06:31 AM
Troy77+79's Avatar
Troy77+79
Is there a way I could test the switch? Anyone know the pinout of the connector that plugs in to the switch? Was thinking of maybe using a jumper wire across the correct pins, if possible? Thanks for the help guys.
Old Aug 24, 2008 | 01:40 AM
TheTinian's Avatar
TheTinian
Mine does the same thing. Has since I bought it. Every now and again it will work and surprise me. I know mine is in the switch, chances are yours would be too.
Old Aug 24, 2008 | 12:54 PM
Troy77+79's Avatar
Troy77+79
Update:
Hey, just thought I'd update this. It was the switch. With the key off, I pressed down hard repeatedly on the switch 20-30 times thinking it might clean the contacts inside if they were dirty. And sure enough, it works fine now! If it does it again, I'll see if I can take the switch apart and clean it up.
Thanks for the help everyone.
leonskiau
Aug 27, 2013 01:18 PM
leonskiau
1997 - 2003 F150
Aug 26, 2013 10:46 AM
jdguest
Jan 19, 2011 05:39 PM
gvsuman
Aug 4, 2010 07:26 AM
alloro
Feb 12, 2009 07:59 PM
