2WD balljoint replacement - instructions?
Old Aug 19, 2008 | 08:05 PM
GoCamping's Avatar
GoCamping
Question 2WD balljoint replacement - instructions?
Hey guys,
During my differential saga at the dealer, they informed me that I need new balljoints on the driver's side. I thought "no problem, I can do that myself, how hard can that be."
Well really hard given that my stupid Haynes manual says absolutely nothing on the subject. Actually it does, but it says something like "at the time of this writing the balljoints are not known to be replaceable." Boy that's a crock.
Anyway, is there another manual that tells me how to do this, or a write-up on the web maybe?
Thanks!
Mark
Old Aug 24, 2008 | 08:19 PM
1nascar24fan's Avatar
1nascar24fan
@ wheel drive balljoints
I guess everyone has 4 wheel drives on here.LOL,I was wondering the same thing.
Old Aug 24, 2008 | 08:28 PM
F350-6's Avatar
F350-6
Don't forget you'll need a lot of cuss words during the change. You can ditch the Haynes manual. We've got links to the Ford Service Manual if you never got one of those on cd. Click on these links and bookmark them.
2000 Workshop Manual
2000 PC /ED Manual
Old Aug 24, 2008 | 09:18 PM
1nascar24fan
These are great but they dont help with removal or install.
Old Aug 24, 2008 | 09:37 PM
F350-6's Avatar
F350-6
Look under Group 4 Suspension
SECTION 204-01A: Front Suspension — 4x2
On the left side, scroll down to the heading Removal and Installation. The second item on the list is Ball Joint.
See if that helps you. Most of the auto parts stores will loan / rent you a ball joint press if you buy the ball joints from them.
Old Aug 24, 2008 | 09:52 PM
white Buffalo's Avatar
white Buffalo
I said screw it and just paid to have it done. In a few hours Jon had it done and I would have been there all weekend and probably would of ran out of cuss words and or beer.....
Old Aug 25, 2008 | 03:03 AM
shabangles's Avatar
shabangles
I changed the balljoints on my 2wd about 6 months ago and it was no problem at all. I had the help of an friend that who is a professional mechanic and it only took about 2 hours to do both sides. If I remember correctly all you have to do is remove the tire, remove the caliper, remove ball joint nuts and drop the spindle, then press out the lower and upper. There is also a shim around the upper that must be removed by loosening the horizontal bolt on the axle C. All in all, it was not as bad as I thought it would be.
Old Aug 25, 2008 | 08:38 AM
F250_'s Avatar
F250_
Depending on the tire size you're running or plan to run, this is a good time to install an adjustable caster bushing for improved flexibility on future alignments.
Also, make sure to re-install serviceable ball joints, like Moog. I still have one side to do myself after paying a shop to do the passenger side in a crunch for me earlier this year. The shop did a fine job, but doing it myself can save me several hundred dollars.
Old Aug 25, 2008 | 07:17 PM
1nascar24fan
thanks F350-6,I must have missed that,,appreciate the info
Old Aug 25, 2008 | 07:23 PM
F350-6's Avatar
F350-6
Don't feel bad. I missed it at first too, and thought that can't be right. I saw it the second time through. That manual reads like stereo instructions, but you get used to it after a while.
Old Aug 30, 2008 | 02:36 PM
GoCamping's Avatar
GoCamping
Hey guys, I took the chance and went for it last weekend. It was relatively easy getting to where I had the knuckle off but got a bit more difficult after that. I rented a balljoint press but they were really tough going in - used the impact wrench to "persuade" it. On top of that the spacers that were in the kit didn't work right so I had to rig something. But I'd do it again, knowing what I know. And I used moog serviceable joints too.
Thanks!
