23 MPG...Thanks DP Tuner!!!!
Old 08-26-2008, 09:20 PM
upnorthman
upnorthman is offline
upnorthman is starting off with a positive reputation.
Smile 23 MPG...Thanks DP Tuner!!!!
I just thought I would give anyone interested in a programmer for fuel milage and more power to look no further than the guys at DP. I installed one on my 2001 Excursion just before Thanksgiving..I was imediatley driving the winter fuel and noticed a ton more power..80 econo program..I reallt didn't notice a milage increase until this spring when we switched out of the winter fuel. All I can say is "WOW"...At 70 miles an hour I drove from southern WI. to northern WI and all around up there and back. Amost 750 miles and I have a 1/4 tank left!!!!! Thats 22.8MPG as I figured it out on paper. At 4 something a gallon I am VERY HAPPY with DP Tuner. not to mention the power!! Thanks DP and I hope this helps anyone out there looking to look no further.. Oh yea ...installed myself in less than an hour...AWESOME...
Old 08-26-2008, 09:28 PM
beerdude41867's Avatar
beerdude41867
beerdude41867 is offline
beerdude41867 is starting off with a positive reputation.
What was your MPG before the DP Tuner?
Old 08-26-2008, 09:31 PM
totin_tools's Avatar
totin_tools
totin_tools is offline
totin_tools is gaining momentum as a positive member of FTE.
Did you put a brick under the pedal or something. I wish I could get that kind of mileage outta mine.
Old 08-26-2008, 09:33 PM
Dustin1690
Dustin1690 is offline
Dustin1690 is gaining momentum as a positive member of FTE.Dustin1690 is gaining momentum as a positive member of FTE.
Wow very impressive mpgs
Old 08-26-2008, 09:41 PM
bigsteve1969's Avatar
bigsteve1969
bigsteve1969 is offline
bigsteve1969 has a good reputation on FTE.bigsteve1969 has a good reputation on FTE.bigsteve1969 has a good reputation on FTE.
i got 22mpg with a diablo preadator but i was only running 60-65 and i was coasting downgrades and such
Old 08-26-2008, 09:50 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
PowerstrokeJunkie is offline
PowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to behold
I got about 11 last tank with my DP Tuner.
Old 08-26-2008, 10:15 PM
jeff7825's Avatar
jeff7825
jeff7825 is offline
jeff7825 has a good reputation on FTE.jeff7825 has a good reputation on FTE.jeff7825 has a good reputation on FTE.
The best i've gotten is just under 18, 17.8 or something like that. That was running between 70-75 on the way back from the beach this summer.
Old 08-26-2008, 10:23 PM
Fordbronco69's Avatar
Fordbronco69
Fordbronco69 is offline
Infidel
Fordbronco69 is gaining momentum as a positive member of FTE.Fordbronco69 is gaining momentum as a positive member of FTE.
Idk why but I know a few 7.3L that get high teens low 20's for MPG in WI. Most of them only have an intake and exhuast with no prog/tuner.
You think it might have somthing to do with the fuel we get here? or maybe just driving habits? I got on mine quite a bit and still could drive around for two weeks of going to work and rippin around town.
Old 08-26-2008, 10:29 PM
Red Monkey's Avatar
Red Monkey
Red Monkey is offline
Red Monkey is starting off with a positive reputation.
I think he was relying on his overhead 'lie-o-meter' and didn't divide his milage by the actual gal's used when he filled up especially running 70mph!
Just my .02
Old 08-27-2008, 08:00 AM
deereman4020's Avatar
deereman4020
deereman4020 is offline
deereman4020 has a great reputation on FTE.deereman4020 has a great reputation on FTE.deereman4020 has a great reputation on FTE.deereman4020 has a great reputation on FTE.
My dad hand calculates his mileage and he consistantly gets about 16 mpg on winter diesel and about 17-18 on regular diesel and he drives like a normal person. (the truck is listed in my sig)
Old 08-27-2008, 08:11 AM
zx250's Avatar
zx250
zx250 is offline
Of the next Riffraff East
zx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant future
While I know that my DP-tuner will get better mileage if I drove it easier, the only way I could ever get that kind of mileage is if I mounted the chip to the underside of the pedal the ran the cable up my leg and tied the end around my,,,, well you get the idea. I have did over 18mpg with my DP but that wasn't any fun. I have got 10.5 and that was a lot of fun but expensive. I usually get 15 +/- 1 and that's affordable fun.
Old 08-27-2008, 08:17 AM
indebt's Avatar
indebt
indebt is offline
indebt has a very good reputation on FTE.indebt has a very good reputation on FTE.indebt has a very good reputation on FTE.
Idk why but I know a few 7.3L that get high teens low 20's for MPG in WI. You think it might have somthing to do with the fuel we get here? .
I know it does for gas. If I gas up in Arizona I can get up to 4mpg better? Yet another reason this state sux. Better emissions, but worse mpg.....hmmmmm does'nt that mean I use MORE gas? S#$%^ M*@#$^ F#$%^ D&*(^ state government .
DieselCamper01's Avatar
DieselCamper01
DieselCamper01 is offline
DieselCamper01 has much to be proud ofDieselCamper01 has much to be proud ofDieselCamper01 has much to be proud ofDieselCamper01 has much to be proud ofDieselCamper01 has much to be proud ofDieselCamper01 has much to be proud ofDieselCamper01 has much to be proud ofDieselCamper01 has much to be proud of
WAAAAAYYYY better than anything I have ever gotten. Running stock except the mods in my sig. Best I have seen with pretty light pressure on the go pedal is 15.5. Congrats if that is really your true mileage Upnorthman. I am jealous. Is your EX 4X4?
Old 08-27-2008, 09:00 AM
brian42's Avatar
brian42
brian42 is offline
brian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant future
Stock intake (except aFe drop-in filter), stock exhaust, no programmer and I get between 16 and 17mpg's (depends on my mood and my right foot that sometimes has a mind of it's own). Last tank was mostly highway and I got 17.8 hand calculated mpg for the tank (540 miles before the low fuel light came on).
Now if I can just convince my wife that the DP tuner will pay for itself in a few months...
Old 08-27-2008, 09:04 AM
zx250's Avatar
zx250
zx250 is offline
Just for future referance, keep that fuel tank above 1/4 and you will get even better and you engine will thank you for it. Stock design allows for air in you fuel lines when it gets much below 1/4 mark and that makes it unhappy, hench the reason for the in tank mods.
Quick Reply: 23 MPG...Thanks DP Tuner!!!!
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
