weight reduction
Old Aug 19, 2008 | 12:03 PM
bumper.45acp's Avatar
bumper.45acp
weight reduction
I was wondering if anyone had any tips on weight reduction or transfer on these trucks. I have a roll pan in the back, and I plan to move the battery to the bed, but not sure what else I could do that would be safe. It is an 88 f150 swb 2wd 460 c6 9inch rear 3/5 drop.
Old Aug 19, 2008 | 01:10 PM
quicklook2's Avatar
quicklook2
moving the battery to the rear will not accomplish much in these trucks.
Old Aug 19, 2008 | 04:39 PM
85e150's Avatar
85e150
The biggest lump is the 460.
Swap to a smaller motor & trans, or swap heads and manifolds for aluminum & headers.
Drilling big holes in the frame invites rust and cracks & won't save much.
Acid dipping the body would be quite expensive & you couldn't lean on it or even take it into a hard rain storm...
Removing ac/ps/pb/pdl/pw even manual window regulators all conspire to produce a joyless driving experience....
Old Aug 19, 2008 | 04:52 PM
quicklook2's Avatar
quicklook2
answer the question: what are you trying to achieve?
Old Aug 19, 2008 | 05:36 PM
bumper.45acp
I am wanting to keep the 460, and I will be adding some things like sound insulation, and stereo. I was just hoping to find something to offset my added weight a little bit, where maybe I could get a little closer to factory weight. I think the 460 probably added 250lbs or so, I am not sure.
Old Aug 19, 2008 | 05:40 PM
alz's Avatar
alz
It may have added 250lbs, but you gained a butt load more tire spinning torque.
Do they make a fiberglass front clip?
Old Aug 19, 2008 | 05:42 PM
quicklook2's Avatar
quicklook2
what motor was in it orig.?
Old Aug 19, 2008 | 05:52 PM
bumper.45acp
I was hoping to put a 94 or so front clip on it, to make a 1st gen lightning clone. I havent seen a clip in fiberglass, but I havent looked either thats a good idea. At least a fiberglass hood.
It had a 300 6cyl in it.
Old Aug 19, 2008 | 06:17 PM
preppypyro's Avatar
preppypyro
Not meaning to hijack your thread, but how hard was it to put the 460 in there?
Is it efi'd or carbed?
Old Aug 19, 2008 | 06:26 PM
bumper.45acp
It wasnt to bad, I just had to rig up some motor mounts, and I used the factory low psi fuel pump. Theres nothing major to it, its pretty easy. The big blocks make are so much easier to make power than a small block. It engine dynos about 520hp, and its not a high dollar build, not much more than stock. Ported heads, flat tops, 0 decked block a good cam and aluminum intake, thats pretty much it. It would have cost me a fortune to make that kind of power with a smallblock, I couldnt justify the weight savings vs. cost.
Old Aug 19, 2008 | 06:40 PM
preppypyro's Avatar
preppypyro
Thats really cool, you know we wanna see some pictures of that now though
Old Aug 20, 2008 | 11:29 AM
bumper.45acp
I have emailed a guy that makes fiberglass front clips, roll pans and tailgates all aimed to reduce weight. I will update with any more info, because I dont know how much weight they will save.
Old Aug 20, 2008 | 03:15 PM
stngh8r's Avatar
stngh8r
-Aluminum wheels
-Aluminum heads
-Headers
-Mock front bumper
-No Tailgate
-No spare
-light weight battery (if it'll crank a 460)
-pass. side mirror!
-big single exhaust rather than dual's.
-shorter exhaust length, exit just after cab for example.
-Disc brakes?? (kinda reaching on that one.)
-One gas tank instead of two?? (reaching again.)
Man, I can't think of anything else unless you start taking off creature comforts like AC, PS, dash, carpet, factory seat, etc..
Old Aug 20, 2008 | 06:10 PM
jarod17's Avatar
jarod17
Yes there is a fiberglass front clip for these trucks. I was looking at one for my '96 that goes for about $1500. It is a one piece item designed to make the front clip tilt forward like the semi's do. I have seen other fiberglass parts for these trucks but not many.
Old Aug 20, 2008 | 08:32 PM
john410312's Avatar
john410312
Originally Posted by stngh8r
-Aluminum wheels
-Aluminum heads
-Headers
-Mock front bumper
-No Tailgate
-No spare
-pass. side mirror!
Get a skinnier girlfriend. (Non oem lady bumpers only add 2-3 lbs) That'll help the weight problem some, if it's absolutely necessary to have a pasenger. And eat a salad youself.
