EGR Delete, What else??
Old Aug 18, 2008 | 09:33 PM
RDCampbell's Avatar
RDCampbell
Smile EGR Delete, What else??
2003 F-450 6.0l
Heavy Towing
I'm doing an engine swap, ad the cab is still off. What should I do while I have it off?
1. Y Pipe Cut, weld , blocking plate.
2. Water coolant filter
3. Oil cooler??????????????
4.???????
I'm wanting to install the engine on Thursday/Night.
Need to order parts Tuesday,,,,Help
Thanks
RD
Old Aug 18, 2008 | 09:53 PM
liv's Avatar
liv
headstuds
and this FDDTS - New One-Piece High Pressure Oil Connector
Oil cooler is prob a waste of time. All you can really do is replace it and they arn't cheap
also clean the turbo while its out
just my .02
Old Aug 19, 2008 | 01:54 AM
bismic's Avatar
bismic
I would also:
install the larger turbo oil drain line
pull the IPR to inspect the screen
replace the HPOP screen (as long as you are there replacing the fitting)
Old Aug 19, 2008 | 06:24 AM
RDCampbell's Avatar
RDCampbell
The engine only has 17k miles on it.
Old Aug 19, 2008 | 06:40 AM
bismic's Avatar
bismic
What is your objective with the project?
