Pulling Flathead Questions
Old Aug 18, 2008 | 09:06 PM
Case1950's Avatar
Case1950
Hey guys,
I have never pulled a flathead from a vehicle before and have a few questions. Which bolts do you use to pull the engine? I take it, it is a couple of the intake bolts? Which ones do you normally use?
Thanks,
Case1950
Old Aug 18, 2008 | 11:28 PM
Snowking's Avatar
Snowking
Whenever I have pulled a flathead out I normally use 2 opposite head bolts.
Old Aug 19, 2008 | 07:18 AM
petey shoes's Avatar
petey shoes
snowking's right. head bolts are strongest, intake bolt bosses are too weak to gamble with!!
Old Aug 24, 2008 | 11:21 AM
Case1950's Avatar
Case1950
Thanks guys,
I will try and pull it the next free day I get.
Case1950
Old Aug 25, 2008 | 10:50 AM
45ford's Avatar
45ford
I've found that using an adjustable lift device works well with any engine, but particularly well with the flathead
When lifting flatheads with aluminum heads, I have no qualms about using FOUR intake bolts.
Mike
