1999 rear end howl
I bought my 97 F-150 4X4 used w/ 64,000miles on it and the rear end (3.55 LS) would make a howling sound when u accelerate and it would stop if u let off the gas,it did it the worst at 45mph.
I talk to the guy who owned it before me he said it always done it since it wuz new and had Ford replace the chunk when the truck was still under warranty but that still didn't fix the problem.
I drove until it had about 110,000miles on it and one night I wuz coming home from work it started howling like never before,well it locked up on me going down S.R.80.
Up until that point though it never changed tone or nothing to indicate it was about to give up just that one night bam.Turns out it was the carrier bearings,I replaced the whole rear axle and just swapped the brakes off the old one too it.
Dan
Dan
I just changed mine. I bought the bearing kit from Randy's Ring and pinion. $250 the outer axle bearings from NAPA. $100 It took about 6 hours. It was a PITA. It requires a few special tools such as dial indicator, dial calipers or micrometer, torque wrench, inch pound torque wrench. Cured the problem.
Did you have someone helping ya, or great directions?
resq302
08-21-2018 10:29 AM
compaddict
03-18-2014 05:23 AM
