Hard gear shift Differential ratios
Old Aug 18, 2008 | 12:21 AM
dads truck's Avatar
dads truck
I have just finished installing an 302 V8 engine and and four speed automatic trany from a 91 F150 into my 64 pickup. My differential is from the 64 with a set of 4:10 gears, I am planning to change over the differential from the 91 that has a set of 3:55 or 3:56 gears. The 91 truck had a trailer package. What would the ratio be for a none trailer package truck.
Does the 4EAO tranny hard a hard shift?
Old Aug 18, 2008 | 07:40 AM
quaddriver's Avatar
quaddriver
the rears were whatever were ordered - trailer tow or not. the 5.0 IIRC had 3 options in 91 - 3.08, 3.55 and 4.10, and each ratio had a tow rating.
I dunno what a 4EAO tranny is, in 91 the autos were AOD and E4OD. The E4OD isnt doing much shifting without a PCM. Did you graft everything including the EFI?
Old Aug 19, 2008 | 10:32 PM
dads truck's Avatar
dads truck
Hard shift
Sorry I got the model to the tranny mixed up. Yes I have grafted the ECM into the old truck along with fuel injection.
The first to second shift is at about 10 to 15 MPH even when I put the foot on the floor, it's into overdrive by the time it gets to 40 MPH.
Old Aug 19, 2008 | 10:48 PM
quaddriver's Avatar
quaddriver
Ok now I need to know if this is AOD or E4OD tranny.
shifting way early is a sign of an AOD without the TV cable hooked up right
Old Aug 20, 2008 | 07:46 AM
clerk's Avatar
clerk
In 91 most 302s had AOD in them. It may be the AODE which had electronic controls, not just the TV cable.
I believe that the 64 truck has the 9 inch rear in it. I would keep it if you don't need the tone ring for the electronics. It is not hard to find other center sections with different ratios to swap.
just my thoughts.
Old Aug 20, 2008 | 07:57 AM
Conanski's Avatar
Conanski
Sounds like the computer is not getting the speed input it requires from the vehicle speed sensor(VSS), this makes the computer go into limp mode and max out the tranny shift pressure in an attempt to prevent damage. The VSS would have been on the tranny tail shaft or in the rear axle, so if your tranny doesn't have it you may need to put the '91 axle under there and connect the RABS/VSS sensor to the computer.
Old Aug 22, 2008 | 02:14 PM
dads truck's Avatar
dads truck
Hard shifting
It is the electronic tranny and the speed sensor is working as I have an electronic speedo (the problem excited before the speedo was installed).
The rear axle is a Dana 44
Old Aug 22, 2008 | 03:19 PM
quaddriver's Avatar
quaddriver
change the speedo gear to 23 teeth from transmission center and see if that helps - they have a specific part number to allow these to run with 4.10 gears.
AOD, AOD Performance Transmissions from PATC, AOD Transmission, AOD Mustang, AOD
3.55 'thinking' electronic tranny in a 4.10 world means about 15% lower shift point. the pcm thinks you are going faster than you really are.
Old Aug 22, 2008 | 05:57 PM
Kemicalburns's Avatar
Kemicalburns
that tranny requires info from the vss like conanski mentioned. so what if you have an electronic speedo. the truck would get that signal from the vss located in the transfercase on a 4wd of that year or the rear end. so you need to take out your D44 rear end and install the 8.8 out of the f150 and run the proper wiring to the ecm from that sensor thats mounted to the top of the pumpkin.
Ford Fuel Injection might have some info on this as well. you probably would be better off pulling that E4od and placing an AOD in its place which isnt controlled by the computer at all.
Old Aug 23, 2008 | 07:46 AM
dads truck's Avatar
dads truck
Thanks guys it looks like its time to replace the 4:10 gears with a set of 3:55 or lower.
Happy truck'n
Phil
jaq
6.4L Power Stroke Diesel
Nov 2, 2012 07:13 PM
Teamrope
Feb 11, 2011 08:42 AM
dads truck
Dec 1, 2008 07:34 PM
dads truck
Oct 10, 2008 07:11 PM
d0n_3d
1983 - 2012 Ranger & B-Series
13
Dec 18, 2003 04:23 PM
