Trailer Tail Lights not working
Old Aug 17, 2008 | 09:11 PM
threeboysandadog's Avatar
threeboysandadog
The trailer tail lights on my 2000 X are not sending a signal from the plug in at the receiver. I have checked all fuses and they seem to be in order. Blinkers and brakes work. Only the tail lights will not work. I have checked the tail Light signal at the receiver and there is no voltage. Seems like a fuse issue but can't find the culprit. Any ideas?
Old Aug 17, 2008 | 09:19 PM
nateolson00's Avatar
nateolson00
check to make sure your plug is seated well. is it the round 6 or flat 4?
Old Aug 18, 2008 | 05:34 PM
X-70STANG-F150's Avatar
X-70STANG-F150
i've never looked to see how the x is wired, but in previous years Ford had a plug in connector in the rear of the truck near the receiver. you could buy an adapter and plug it into that connector for your hitch plug-in. If they still use that connection, that would be a good place to start.
Old Aug 19, 2008 | 05:49 AM
projectSHO89's Avatar
projectSHO89
Check fuse F4 and the trailer running lamp relay, both located in the under-hood fusebox.
Steve
Old Aug 19, 2008 | 10:58 PM
Part-Timer's Avatar
Part-Timer
I second the idea of checking the relay. If all the fuses are good and a test light on the center pin of the trailer socket doesn't light up when the the truck is in reverse then you may have a bad relay. I think the relay is located in the relay box that is closest to the firewall (there are two beside the main fuse box).
Brian
Old Aug 20, 2008 | 07:29 AM
threeboysandadog
Problem solved. It was a relay. Strange. The ford dealer said that all my running lights should not work if the relay is bad. But they did.
jbullfrog
Jan 12, 2018 10:10 AM
96bigblueford
6.7L Power Stroke Diesel
Sep 20, 2013 09:38 PM
armour01
2004 - 2008 F150
Oct 16, 2012 02:11 AM
willrigdon
2004 - 2008 F150
Aug 6, 2011 07:55 PM
hotrodracer
Dec 4, 2007 10:12 PM
