m50d not shifting
Old Aug 17, 2008 | 05:45 PM
crmarshall's Avatar
crmarshall
m50d not shifting
I just bought a 91 ranger 2x4 with a 2.3 and a 5 speed. The motor and tranny had been swapped from another truck and in the process they "buggered" up the QD on the tranny so they just cut the hydraulic line. I had to drop the tranny and replace the slave cylinder just to get the clutch line hooked up. After that mess I jumped in and fired it up. Went to put it in first and it won't go. Shifts into 5th and Reverse but no 1-4. Any ideas? I was thinking maybe the shift forks? Appreciate any input.
Old Aug 18, 2008 | 08:25 AM
jk080's Avatar
jk080
Transmission Rebuilder
Remove the shifter and make sure that all the rails are lined up.
Old Aug 18, 2008 | 07:39 PM
BuffmanLT1's Avatar
BuffmanLT1
that' was my issue when I dropped (2 inches) the trans on the ground. Bumped the one rail. got them back where they were supposed to be, trans was fine
Old Aug 18, 2008 | 10:33 PM
crmarshall's Avatar
crmarshall
how do I get the rails in line? I pulled the carpet tonight to remove the top plate access cover only to find out that on this truck you can't get to the front 4 bolts. Do I need to take the top plate off or can I line things up through the shifter hole? I really don't want to take the tranny out again but if that's what it takes it really isn't that bad.
Old Aug 19, 2008 | 09:57 PM
BuffmanLT1's Avatar
BuffmanLT1
have to get the shifter off. Should be three torx screws.
Old Aug 20, 2008 | 09:41 AM
crmarshall's Avatar
crmarshall
Thanks
I was able to get the rails in line last night (pretty self explanatory once you look at it) You guys just saved me from pulling and possibly replacing a good tranny. Thanks!!!!!!
