EFI conversion
Old Aug 17, 2008 | 02:55 PM
joestratton1's Avatar
joestratton1
EFI conversion
Hi guys
I am going to convert my 84 F250 from carb to EFI. I have the EEC-IV computer and feedback carb stock (hate it). Going to pull intakes, injectors, and computer from junkyard. My question is with the EEC-IV (OBD-1) system am i stuck with the speed density EFI or can i use MAF? Did MAF ever come stock with EEC-IV?
thanks, Joe
Old Aug 17, 2008 | 04:47 PM
subford's Avatar
subford
You did not say what engine but I think it would be easier to use a MAP (speed density) system from as close to your truck as you can find, say a 1986 or if you have a 460 1988.
Yes it did.
Old Aug 17, 2008 | 05:46 PM
joestratton1
Sorry its a 351w. There's a 85-86 bronco at the junkyard guess I'll use that.
Old Aug 17, 2008 | 06:03 PM
subford's Avatar
subford
Make sure you get all of the engine compartment wiring and sensors. the Bronco should have the same engine and transmission also.
You may want some of the cab wiring also so you can plug in the engine wiring to the cab wiring.
You may want to see if the salvage yard will sell you the Bronco and then you can take stuff off as you go.
Old Aug 17, 2008 | 06:50 PM
joestratton1
Do i need the sensors? will they be the same sensors i have?
Old Aug 17, 2008 | 07:06 PM
subford's Avatar
subford
You will at least need the MAP sensor and as I do not know what other type of sensors you have I can not say for sure. But some should be the same.
Old Sep 10, 2008 | 04:04 PM
kaboom10's Avatar
kaboom10
Have you finished the swap yet?
