Twin Turbos
Old Aug 17, 2008 | 06:38 PM
deereman4020's Avatar
deereman4020
i could not stand that setup but hey it aint my truck i like the looks of a clean engine bay no pipes all over no wires just a nice clean simple looking engine bay
Old Aug 17, 2008 | 06:42 PM
deereman4020
Originally Posted by strokin_it7.3
$5000 or so would just get you a good port job. The heads are still 2v design, the intake ports SUCK at flowing alot of air, and the HEUI design would be better replaced with a little commonrail injector nozzle. You'd be looking at 30K plus for a set of CNC heads that would be the cats ***!
Anyway, its not about "not wanting" to ram the air in, it's just the only decision you're left with.
i wish i had $30000 cnc sum new heads but for that amount of cash youd be better off just swapping in a cummins
Old Aug 17, 2008 | 06:44 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Might as well sell your truck and get a car with a SBC 350 in it.
Your 7.3 doesnt have pipes and wires running all over the place?
Old Aug 17, 2008 | 06:54 PM
deereman4020
im talking about the pic posted by white buffalo with the twin turbo setup my uncle has a chevy truck (still running i believe it is an 88) with the 350 in it so i get my fill of clean engine bays from that
Old Aug 17, 2008 | 07:59 PM
Orezona's Avatar
Orezona
You might want to Google that guy to see what he has accomplished with the 7.3 engine. He is in the top 5 in the 1/4 I think. That was before the 2 hairdryers. That pic you just saw was a courtesy shot to those who kept begging for pics.
As far as comparing that 20 year old gasser to Luke's truck
Old Aug 17, 2008 | 08:41 PM
PowerstrokeJunkie
Yeah, you said that you couldn't stand having an engine bay look like that, with all the wires, and piping. You'd have to be GAY to not like this-
Old Aug 17, 2008 | 08:56 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Here's a HiJack, Jason, I see you have a 1.0 housing awaiting install. Are you going to wait until it gets cold?
Old Aug 17, 2008 | 09:02 PM
Orezona's Avatar
Orezona
Is that not the sweetest thing you've ever seen!
But it's way more crowded than my old 73 Chevy 1/2 ton I drove back in the 80's
Old Aug 17, 2008 | 09:06 PM
Orezona's Avatar
Orezona
You suck Mike. But.......with the new Scan Gauge I've been hoping to get some Drive Pressure numbers to compare for when I put the 1.0 in. Now I just need to figure out how to figure it out
Old Aug 17, 2008 | 09:14 PM
PowerstrokeJunkie
Old Aug 17, 2008 | 09:20 PM
Tenn01PSD350
Yep, reps for that. Got that gauge up and running yet?
Old Aug 17, 2008 | 09:27 PM
white Buffalo's Avatar
white Buffalo
HIGHJACK
Jason,
Been contemplating buying that gauge all year. Just plug into the OBD port & run a power line right? How's the gauge at night? can you adjust the brightness?
I do want one, just haven't spoken to many that own one except for Chris.
Old Aug 17, 2008 | 09:28 PM
  #28
Orezona's Avatar
Orezona
Everything but the fuel pressure. Just need to get the "analog 1" wired to the sensor and power. It is sweet!
I had to get a fuel block w/ 3/8" npt ports, two plugs, and one 1/8" npt nipple from Jeggs. I already had the under the hood fuel gauge from DI so I just unscrewed the gauge and mounted the block where the gauge was. Should work....
Hey, who derailed this mess anyways?
  #29
lukecline's Avatar
lukecline
how the hell are you going to have twins w/o having piping all over? When you add a second charger things are bound to get tight. Especially when you have to add another feed line, drain line and relocate stuff to make room for the charger. keep in mind my big charger is big enough that i can sit a 32 oz Gatorade bottle on the compressor wheel and it wont touch the compressor housing.
wide open performance is who built the kit for my truck. It is a very big setup yet spools very well on the street. it was well worth the $ spent.
Old Aug 17, 2008 | 09:31 PM
  #30
Orezona's Avatar
Orezona
Originally Posted by white Buffalo
HIGHJACK
Jason,
You only need to run power for the fuel pressure sensor. If you don't get that option then no. The whole thing runs off OBDII power The lighting dims nice. No problems with day or night. I'll start a new thread when I get it all going.
