92 F-150 issues
Old Jul 24, 2008 | 06:53 AM
ewturtle's Avatar
ewturtle
92 F-150 issues
Picked up a 92 F-150 5.8 with an E4OD. Purchased it cheap knowing it wouldn't run. Doesn't matter what fuel tank your using, the fuel pump wouldn't shut off, either one depending on the switch. Long story short, I replaced the ECM and now it will run again. However, it now runs really really rough and has no power. There isn't anything else I should have done when I replaced the ECM was there? I put new plugs in but that didn't help. Since the ECM was going bad, I was thinking maybe an injector went bad due to the constant pressure being fed my the fuel pump when the motor wasn't running but the key being on. I've since learned that the ECM problem was fairly common on those trucks. I will be checking the fuel pressure reg and do a compression check and check the fuel pressure at the rail. I'll also be plugging in my scan tool to see what i can find.
Anyone else have any suggestions other than the changing the wires or ignition coil?
Old Jul 24, 2008 | 08:39 AM
Lazy K's Avatar
Lazy K
Sounds like you have it covered. Definately use your scan tool or at least pull the codes using the check engine light. Good luck.
Old Aug 17, 2008 | 08:09 PM
joenetz's Avatar
joenetz
check ur filters i ur tanks and on ur frame
Old Aug 17, 2008 | 10:08 PM
ewturtle's Avatar
ewturtle
Update.
Tried to pull codes from the new ECM but was unable to do so. I decided to order another ecm. I pulled the replacement one and found a messed up pin. Installed the new ecm and problem solved. Thanks for your suggestions...
May 5, 2014 08:15 PM
1988
Apr 20, 2014 11:14 AM
antiqueynot
1983 - 2012 Ranger & B-Series
25
Apr 17, 2012 11:31 AM
nnewman
Jun 1, 2009 04:55 PM
tim73
May 26, 2006 03:04 PM
