Solenoid keeps going out
Old Aug 16, 2008 | 05:36 PM
kevinkizzle's Avatar
kevinkizzle
I have a 1980 F150 with the 300 I6. I just replaced the starter and solenoid a little over a month ago. Last weekend, I went to start it and it wouldn't start and when I let go of the ignition, the starter was still trying to start the engine. It did this until the battery went dead. I replaced the solenoid and charged the battery and it ran fine for a couple days and did the same thing. I then took back the old solenoid (Borg Warner) and switched it out for a motorcraft. Then today, the solenoid wouldn't disengage AGAIN. Can anyone shed some light on how to fix this permanently?
Old Aug 16, 2008 | 11:30 PM
srercrcr's Avatar
srercrcr
You might try the Electrical forum....I'm leaning more to the ignition switch.
Old Aug 17, 2008 | 01:35 AM
Sycostang67's Avatar
Sycostang67
I'm thinking you ignition switch is sticking as well. Was it still going even after you removed the keys?
Old Aug 17, 2008 | 03:39 AM
shadylane's Avatar
shadylane
Disconnect the small wire from the solenoid. If it stops cranking then its a wiring or ignition switch problem. If it keeps on cranking it has to be the solenoid. I've had several new solinoides that were new, but bad lately.
