6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Dunking the DPF
Old Aug 16, 2008 | 01:13 PM
Leonandlisa's Avatar
Leonandlisa
Dunking the DPF
I have taken my truck to the lake a few times this year but this time I actually noticed the exaust making noise when I backed the boat into the water, do you think I will have an issue with the DPF cooling down so fast under water? The truck isn't shut off so the water is only allowed on the outside of the exaust.
Thanks for any ideas.
Leon
Old Aug 17, 2008 | 08:07 AM
SouthTexasDiesel's Avatar
SouthTexasDiesel
Rapid cool down of the DPF could cause issues. Especially if the truck had just completed the regeneration cycle.
Are you sure the DPF is beneath the surface, and what type of noise is it making?
Old Aug 17, 2008 | 11:06 AM
oilburnr's Avatar
oilburnr
I doubt the dpf was in the water, he would have to be awfully far into the water for that. Most likely he meant the exhaust tip is in the water and making noise.
Old Aug 17, 2008 | 12:00 PM
Leonandlisa
It was a hissing noise when the the tail pipes went under water that I heard but I crawled underneath to take a look when I got home and there is no way that the DPF was under water as I wasnt in that deep.
Leon
Old Aug 17, 2008 | 12:27 PM
cartmanea's Avatar
cartmanea
How deep are you getting the truck?!? The boat should go in the water, not the truck, unless you want to do rear bearings often and a lot of preventative maintenance.
Old Aug 17, 2008 | 03:26 PM
SouthTexasDiesel
As long as the DPF does not get submerged you will be fine.
I bet the odd hissing noise you're talking about was the heat from the tailpipe and exhaust gases coming out from the inter cooler vents on the tailpipe section.
Old Aug 17, 2008 | 04:44 PM
DAFBFD58's Avatar
DAFBFD58
I have to agree with STD. Ir could not find a way out so it found the next best location.
