rpm & gpm
on
1 Post
That's even too slow for me. I am generally not in a hurry at all anymore. But if I am a hold up for anyone I have no problem with driving 75-80 until the traffic allows me to go back to my economical speed. I drive my Vdub 75-80 whenever I am on the interstates. I have zero fear of speed, just a real pain in my wallet when I have to drive my beloved PSD as fast as I would really like to.
No I'm not kidding you. My latest MPG check was slightly laden, some camping gear and 10 cases of beer, about 300 lbs, and from my house to La Sal, UT a round trip of 820 miles I averageg 20.2. That was at elevations at between 5000 ft to just under 8000 ft. When the truck was stock I got 19 mpg. Don't forget to figure in odometer error for the larger than stock tires. My odometer only registers 97 miles for each 100 driven. I add that 3% to total miles for a more accurate MPG figure. That can make a difference. 19.5 MPG uncorrected will be 20.09 corrected.
I never thought about the tires throwing the odo off, thanks for pointing that out. I still don't think I could come close to what you are getting though.
My latest trip I ran ~500 miles holding my speed around 67-68 mph which is 1800-1900 on the tach pulling a 2 place open snowmobile trailer with 2 sleds on it... I'd guess total weight was 1200-1500 lbs but might be wrong there. I also did ~250 miles at the same speed without the trailer. Again, 2 adults/2 kids in the cab, luggage and 2 dogs in the back. Without correcting for tire size I figured 14 mpg, 14.4 if I correct for tire size according to your +3% number. Should I be worried about my economy or not? Maybe the real question is how much does the wind drag from 2 dogs hanging their heads over the side of the truck for 600 miles affect my mpg?
My guess is you got basically the same MPG pulling the trailer as without, and the trailer cost you 2-3 MPG. My 2002 excursion, 3.73, has averaged 17 in mixed driving (about 60/40 highway to city) in the 3k miles since I have had it. Its got a " cold air intake " that I want to switch to a 6637 now that I have a baseline established, factory exhaust,,, ( wish someone made a 5 inch for an ex), and it does have some type of chip.... its a diablo, thats all I know about it.
how you get to your cruise speed can be as important to mpg as your cruise speed....if you can see black smoke you have $$$$ rolling out the exhaust.
Okay here's where I'm at: the first time I checked fuel mileage I was running ~80 on the freeway (2300 rpm or so) and ~68 on the highway (1800-1900 rpm) with 2 adults/2 kids in the cab, a 250lb dirt bike, 2 dogs (~220 lbs) and our luggage for a weekend trip, got 15.5mpg without correcting for tire size.
Get two dogs with smaller heads and re-test. JK. Weight, topography, wind, driving technique and a whole litany of things can effect mileage. It is just strange that there is such a wide range on what kind of mileage comparable 7.3 trucks get. 14 to 23 MPG is quite a gap. Just the luck of the draw I guess.
14.4 was last week, the 15.5 was late spring/early summer. Lately I've been taking her easy, not going over 2K rpm when accelerating and only occasionally going past 2K when passing or coming up a grade. I haven't been running any DK either. And I live in the PNW... there isn't a flat road anywhere!
I just pulled in from a 30 hr. road trip(I drove down to Jacksonville, Fl and picked up the truck I just bought). I averaged 80 mph on the trip down towing a 6k lb. flatbed trailer, I got around 9.5 mpg. No, babying, just hammer down and get there. On the way back with an extended cab, short bed 4X4 F-250 on the trailer at about 70 mph I averaged 9 mpg. Plenty of long hills to pull and lots of construction and traffic.
Mine's been getting around 14.5 average with a mix of city/freeway driving. With my 35" tires i'm still under 2,000 rpms running 80. I've recently fixed the leaking up-pipe donut gaskets and I've dropped my cruising speed to 70mph max for this fillup and I'm going to see what improvement I get. Next tank i'm dropping cruising speed to 65mph which is only around 1,600rpms with my tires. Mods are in signature.
09-27-2005 02:13 PM
