Sponsored by: Auxito
Evap Not Ready
Old Aug 15, 2008 | 08:42 PM
dagodav's Avatar
dagodav
Evap Not Ready
My 99 f-150 has codes po171 & po174 addaptive fuel system to lean banks 1&2. Also evap not ready. Truck ran fine now it wants to die at idle when i come to a stop. Help Me!
Old Aug 15, 2008 | 10:16 PM
AzBlueWolf's Avatar
AzBlueWolf
https://www.ford-trucks.com/forums/7...ml#post6379956
evap wont run with check engine light on, fix codes first
Old Aug 16, 2008 | 09:44 AM
ranger88a's Avatar
ranger88a
No, evap monitor won't run with light on. Check your pcv hose on the back of the intake for a crack and check the maf and see if it's dirty.
Old Aug 20, 2008 | 07:19 PM
dagodav's Avatar
dagodav
MAF cleaning
How do you safely clean the MAF? Where is it located?
Old Aug 20, 2008 | 09:24 PM
73f100shortbed's Avatar
73f100shortbed
Sounds like a vacuum leak with those codes. Like ranger 88 says check hoses from pcv valve. it is pretty common for them to have cracks.
Old Aug 21, 2008 | 06:03 AM
torkum's Avatar
torkum
Evap not ready doesn't mean you have a evap code, it means you cleared the codes or disconnected the battery and the monitor is not ready to read yet. The evap system takes the longest to be "ready".
Old Aug 21, 2008 | 06:48 AM
projectSHO89's Avatar
projectSHO89
It will take even longer (as in NEVER) to run with the other codes present....
Those need to be fixed first.
Steve
Old Aug 21, 2008 | 05:37 PM
dagodav's Avatar
dagodav
Fixed
Found the problem you were right the hose from the intake plenum to the pcv valve was rotted. Codes po171 & po174 are cleared. Now i'm getting po102 MAF low voltage. what would cause that?
Old Aug 21, 2008 | 10:08 PM
AzBlueWolf's Avatar
AzBlueWolf
check to make sure the connection is tight...
did you clean the maf?
Old Aug 22, 2008 | 02:55 PM
dagodav's Avatar
dagodav
MAF cleaning
Not sure exactly how to clean. Is starting fliud spray the way to go? Connection is tight. Reading po102. Getting 11MPG PLEASE HELP!
Old Aug 22, 2008 | 07:54 PM
AzBlueWolf's Avatar
AzBlueWolf
some say carb cleaner, others say electrical parts cleaner
disconnect the battery
remove the Maf from the inlet tube, and spray cleaner into the hole that you can see the wire sensors
short blasts and let dry for a few seconds between bursts
I usually hit the other holes a couple times also
reinstall the sensor and plug it back in...connect the battery again and start the truck
caindog110
Sep 25, 2018 06:24 AM
hmilycar
1983 - 2012 Ranger & B-Series
Jul 9, 2015 11:11 AM
mfp4073
May 7, 2015 10:25 PM
ruger761
6.7L Power Stroke Diesel
24
Nov 14, 2014 03:12 PM
scott the jensen
Modular V8 (4.6L, 5.4L)
Sep 21, 2014 02:11 PM
