need help
Old Aug 15, 2008 | 06:16 PM
3rd car's Avatar
3rd car
Cool need help
i have a 96 explorer and i keep blowing my #26 fuse 10amp and i know this is very bad but i put a 10,15,20 and they all blew is this common or not there is a LOT of rust underneath the truck can any1 help i nave no reverse lights no 4w or no rear deforster and its killing me please any help
Old Aug 15, 2008 | 07:06 PM
marragtop's Avatar
marragtop
Start by looking at what is on the 26 fuse. If the rear def is on it, unplug the clips on it to see if it makes a difference. It may be shorting out there. You can also unplug the reverse switch from the trans to try and narrow it down. Does the fuse blow as soon as you put it in, or when you turn the ignition on, or when you activate an accessory? Do not put a higher fuse in it as you may cause an electrical fire.
Old Aug 18, 2008 | 03:22 PM
3rd car's Avatar
3rd car
wtf now i disconected everything that is on the 26 fuse which is 4x4 o/d rear def and reverse light i took the connectors out for the 4x4 and rear def i took the clips off the rear window and i took the reverse light out and i took the button of the shifter for o/d and when i was the new fuse in it blew going from d 2 i wasnt driving i just was putting the shifter threw all the gears please any help and thanks marragtop
Old Aug 18, 2008 | 04:47 PM
5.0B2's Avatar
5.0B2
Unplug the wiring connector from the transmission selector/neutral safety switch on the side of the transmission and try it again.
Old Aug 18, 2008 | 05:15 PM
3rd car's Avatar
3rd car
k thanks i will try that tomorrow i have to buy some more fuses
kenbozzuto
Jan 6, 2011 06:03 PM
k7tny
New Member Introductions
Dec 10, 2006 09:33 AM
walwar62
Modular V10 (6.8l)
Oct 13, 2003 07:30 PM
nothingbutford
Sep 4, 2003 04:49 AM
croh
Aug 18, 2000 06:10 PM
