4wd question...
Old Aug 18, 2008 | 06:52 PM
xplorerboy's Avatar
xplorerboy
Question 4wd question...
i have a 01 sport trac my question is..when i bought this car the 4wd is not working ..a few months later..i replace the cruise control deactivation switch after i do that i disconnect the negative terminal of the battery for about 15 seconds..when i start the car i've noticed the 4wd hi 4wd lo lights in the dash light up! then i try to engage the 4wd it work's...6 months later..i clean the IAC valve..MAF sensor..after cleaning it i disconnect the negative terminal of the battery for about 15 seconds..when i start the car..try to engage the 4wd it's not working anymore.. i check all the fuse..they all fine...any advice?? thank's..
