leds not working?
Old Aug 15, 2008 | 05:39 PM
crestfallinman's Avatar
crestfallinman
leds not working?
i hooked up 4 leds in my truck in the vents, and i spliced into the radio power and grounds
nothing works, is the ground wire too long?
any thoughts?
Old Aug 15, 2008 | 05:44 PM
Virto's Avatar
Virto
I'm no electrical expert but knowing LEDs have very little draw, is the radio power maybe too much current for them?
Old Aug 15, 2008 | 05:53 PM
football3295's Avatar
football3295
if you spliced into the speaker wires usually they will light up with the beat of the music because the higher the beat the more juice going to the speaker but there isnt allways a lot of juice pushing to speaker so i would hook them up to something elese.
Old Aug 15, 2008 | 05:56 PM
88F-150pimp's Avatar
88F-150pimp
No offense, but I think you need to read up on LED's a little bit before you continue. Most LED's operate at around 2 volts and somewhere around 10 to 20 milliamps of current. This varies of course, but you get the idea. Hooking these directly to your 12V radio power will blow the LED's out in seconds. Secondly, you can wire the LED's one way, as they are diodes, not lightbulbs. positive to the anode, negative to the cathode. The anode is the longer lead of the LED. So....make sure your LED's are connected the right way, and wire in a resistor so that your LED's are seeing the proper voltage and being fed the appropriate amount of current. Of course make sure your ground is good (~ 0.0 ohms to battery negative) and you have voltage at your radio power wire.
Old Aug 15, 2008 | 06:34 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You need to know the voltage and current ratings of the LED's you're using and the source you're powering them with.
Then check this out in order to find the proper resistor to use w/ them.
hth,
Old Aug 15, 2008 | 09:05 PM
crestfallinman
oh i forgot to say that they are 12 volt led with 4 leds in each
i figured the radio would be good only because it turns on with the ignition and it was easy to splice into
Old Aug 15, 2008 | 10:41 PM
quaddriver's Avatar
quaddriver
Most LEds use for decoration have the resistor cast in the lexan now. but they are P-N junctions - aka actual diodes (I freak people out by using LEDs to rectify AC)
anyways, your amp has 12v power source and likely has a built in inverter to run +12v/-12v at the amp rails - wide open. any less volume and the voltage is less. and since the amp output is actually a sin wave (ac current) you will get enough 'on time' each second to see it, BUT, since the speaker is 4ohm, and the LED is (how many watts or mA of current?) what is that kirchoffs? law (its been a long time since I studied) says most of the current by far will skootch down to the speakers.
just for grins, toss in a 1K resistor (just in case) and hook up to 12v and see if you get anything. btw - there are tri color LEDS (simply a red and a green nose to tail) that show yellowish under ac
Old Aug 16, 2008 | 11:52 PM
crestfallinman
i got them ll working it was a bad power connection that was killin me
thanks for all of your help
