running rough with black smoke???
Old Aug 15, 2008 | 05:22 PM
1994diesel's Avatar
1994diesel
ok, i have a new air filter, fuel filter, oil and oil filter, new injectors, and new o rings with return lines. and it runs like its missing when idling but it isn't consistent, it will also rev up under normal acceleration or on cruise control, i have read the other post in which other people talk of similar problems and tried some things,
i did try turning to the on position(where the wait to start light comes on) and i took the two wires off of the top of the i.p. and put them back on, and it did click. soo... im not shure what that means but i do know its normal?
basically im trying to pin it down to air intrusion, bad i.p. or bad i.p. gov.
or could it be a bad fuel pump?
im stumped. lol
Old Aug 15, 2008 | 05:44 PM
LilDuke's Avatar
LilDuke
Is it only at idle? Does it do it on light throttle? Heavy accel?
The gov isn't it. That only keeps the throttle at a specific rpm(+/- 5%) based on your foot/throttle position. Just like a garden tractor and such. If the gov didn't work, it would go into a runaway situation. Basically the engine goes to max mechanical rpm limit. and unless you block it's airflow, it'll gernade.
It could be air, bad injectors, or IP. It also could be headgasket, cavitation, valves, etc. Do a compression test on it. See if theres a low cyl. Cheaper than an IP.
Does it smoke at all when idling?
is there a puff out the tailpipe coresponding to the miss?
Old Aug 15, 2008 | 07:28 PM
FORD MEGA CAB!!!'s Avatar
FORD MEGA CAB!!!
It almost sounds like you have air getting into your fuel system. Is it hard to start every now and then. Have you ran it recently with a full tank of fuel?
Old Aug 16, 2008 | 12:09 AM
1994diesel's Avatar
1994diesel
yes!
yes it is hard to start, and i have tried to start it with a full tank recently, same behavior. if i dont rev it up for the first couple seconds to get it through the sputtering it will stall. after it do that it will run fine. if i dont rev it up it will stall out and be extremly hard to start. this is why im leaning towards air intrusion.
i was thinking... is it possible that something might be wrong with my fuel pump and it is letting fuel leak back into the tank while it is off? and it could be letting air in if it lets fuel out. i see no visible leakage from it. i dont even see any visible leakage anywhere under the hood.
The injectors are new, brand spankn new, so are the o rings and the return lines, not even 250 miles on them!
the black smoke is coresponding to the miss, and it only puffs little bits of black smoke while idling, so its not alot, and the smoke from heavy acceleration is normal.
i just want to clarify that it is not white smoke, so i dont think its cavitation.
Old Aug 16, 2008 | 01:38 AM
FORD MEGA CAB!!!
Ya, when mine gets air in the system it does the same thing, smokes black alot and will stall if you don't keep the rpms up. I think your already on the right path with the fuel going back down into the tank. I believe that the lift pump on the side of the engine has a one way valve in it and should help prevent this. The diaphram could also have a small pin hole in it. Since its not too hard and expensive, that pump would be one of the first things I would change. I changed mine in o-rilies parking lot in like 15 minutes while it was hot. I wouldn't suggest getting the cheapest brand of pump either. The one I bought was $45 which was $20 more than another parts store. Looked like a better pump as well. Also, can you put a clear line inplace of the pressure line to the injection pump. The you can see if you have air intrusion. Also, the clicking you described is normal. That is the fuel shut off solonoid working, which is a good thing. Good luck
Old Aug 16, 2008 | 03:00 AM
1994diesel's Avatar
1994diesel
hey thanks
thanks for the advice, really helps, i will try that and i will keep you posted.
Old Aug 16, 2008 | 10:16 PM
KJLYPW's Avatar
KJLYPW
Have you checked the timing? new injectors with good pop off pressure will fire later than the old ones did. If you didn't check the timing when you put in the new injectors, your IP could be too far advanced. Also makes for harder starting and black smoke?!!
Old Aug 16, 2008 | 11:24 PM
speedrdr's Avatar
speedrdr
is your fuel filter one that has the built in water separator or is it like the one in mine that's in a housing with a cup under the bottom of the filter with a water separator fitting on it? if it's the latter, it may be that the drain isn't shutting off completely and is letting air in the system that way. been there done that, have a patch of dead grass in the yard as a result. had to rebuild the cutoff assembly inside to make it stop. mine did the same thing on start up and was making me crazy----well, crazier. maybe this will give you a different direction to look if the other things don't correct it.
speedrdr
Old Aug 17, 2008 | 02:18 AM
Dodge/Cummins's Avatar
Dodge/Cummins
I'm voting for air in the fuel "feed" line/system especially since you talk about it "increasing rpm" under acceleration or on cruise control.
BTW when I first got on this site I thought the "two flats" in you signature was refering to your tires. LOL
Old Aug 17, 2008 | 10:08 AM
1994diesel's Avatar
1994diesel
lol! well believe it or not, i actualy got two flats after i bought it, but the " two flats" in my signature is refering to the i.p. hell when i first got on here i didnt even know if my was a p.s. or and idi! lol but i guess everyone has to start somewhere.
Old Aug 17, 2008 | 03:57 PM
89ford73's Avatar
89ford73
check the short hose from the fuel lift pump to the fuel line on the frame rail. just replace it. its cheap and easy and they leak all the time. make it long enough to loop it without kinking it. but make sure it is not rubbing on the framerail or fuel pump or anything else under there. hope this helps
Old Aug 17, 2008 | 07:01 PM
1994diesel's Avatar
1994diesel
It starts and runs like a champ!!! thanks for all the advice you guys, really big help =D
Old Aug 17, 2008 | 07:17 PM
KJLYPW's Avatar
KJLYPW
So just so we can all learn from your experiance- what did you find to be the problem???
Old Aug 18, 2008 | 06:21 AM
FORD MEGA CAB!!!
Yes, please fill us in.....
Old Aug 18, 2008 | 05:12 PM
1994diesel's Avatar
1994diesel
well it was the lift pump that was the source of all my problems, and it took a while for me to replace it myself because, as the warning that came with the carter pump states "if the pump is installed at any other position that low cam, the pump will be ruined, the engine will stall and damage may result"... now two thoughts came to my head after reading this, first what the hell is low cam, second why the hell did they make it so vague??? lol but eventually i figured it out on my own. i didnt have time to get on here and ask you guys the first question but everything worked out.
it idles so incredibly smooth it makes me wonder if something is broken! lol i guess thats just the new fuel pump complementing my new injectors!
