I am new to this forum, I have been reading the posts for awhile now and thought I would join. I just recently bought a 1987 Ford F350 Crew cab with a 6.9. It has a Banks sidewinder, Gearvender overdrive, C6 transmission, and many other options. The old guy that had it, put basically every option he could to enhance the pickup. Here is the question for all you experts, Can I safely tow my fifth wheel (27 ft, about 8,000 pounds) in overdrive without damaging the transmission? Also, what kind of mileage should I expect with the setup I have, both towing and empty. I have 285/75/16 tires, not sure what the gearing is, but seems very low, 55mph at about 2500 without the overdrive. Thanks in advance for all the input.
Sorry about the confusion, I am wondering if it is safe to tow with the Gearvender engaged. I did one trip and it seems to shift smooth when needed and had no problems. I don't have a transmission temp gauge and wondering if I do tow with the Gearvender engaged if I should invest to see what the tranny is doing.
First of all, thanks for the response and information. I do have a larger tranny cooler and a pyro. It never went above 950 on the pyro and seemed to do fine. I think I will get the tranny temp gauge though just in case. Look forward to future discussions. Thanks again.
I'd say you have 4:10 gears also. Just watch the temps and you should have no trouble. You can run in OD under heavy throttle all day long as long as you keep the temp in check.
I have only pulled on hill so far that I had to drop out of OD pulling a 28' fifth wheel. Most hills I drop down to between 60-65 mph and it'll hang right there. My 6.9 pulled better and got better fuel mileage than the Cummins I have now. 3:55 gears would be better in my experience. I've run both 3:55 and 4:10 ratio's.
I am not sure where the thermocouple is located, how do I determine? Not much of a mechanic, but could figure it out with an explanation. Thanks again.
It should be a little probe either along the manifolds or right after on the exhaust pipes. There will obviously be a little wire connected to send the signal to the gauge.
On 6.9 diesels most turbo setups are aftermarket kits installed by owners, at least the eighties trucks were. The PYRO kits too followed the trends at the time, and may be from many different sources.
*"MONGO not real smart, but MONGO can carry heavy stuff..."
The ATS and Banks exhaust was 3" and had a bung welded by the turbo for the pyrometer probe. In the late 80's and early 90's you bought the turbo, added exhaust, added pyro and boost gauges for a total of about $1875 discounted price. No discount ran from $2,100-$2,400. Installation was extra.
The 285/75/16 tires are most likely throwing the speedometer off a bit (show slower) accurate mpg calculation will be tough. I'd say 12-14 empty, 9-10 loaded. You should have no trouble pulling with the C-6 in 3rd and OD.
TransGo makes a good shift kit for the C-6. Make sure to specify for a diesel though as there are a couple of internal differences between the gas and diesel C-6 trannys.
In response to most replies, I did buy the truck in Oregon and it is 4wd. I just got it painted and looks sharp. I am biased of course. I think I got a good buy, paid $3850. It has airbags, cluster of gauges, Gearvender, 80 gallon tank with pump in the bed that directly feeds to the front tank, CB, 10 disc changer under the back seat, AC, etc. What do you guys think? Good buy? Just curious. Haven't found the thermocoupler yet though. Will look today and respond. Thanks again for the info.
