Another 6.0 question
Old Aug 14, 2008 | 05:48 PM
25-06shooter's Avatar
25-06shooter
Sorry about using my first post to ask for help, but this thing is driving me crazy. I've been reading for several weeks now and it looks like you fellas have a great site.
I have an '04 Excursion with 95,000 miles on the 6.0. It is doing the surging, rough running, and sometimes completly shutting down. I cleaned the EGR with no change, so I unhooked the EGR and removed the butterfly valve. Again, no change. I removed and cleaned the EBP sensor (it was almost completly sealed off) and pipe.......it might have helped a little, but it might also be wishful thinking. It is still surging and running rough. It only does it after the truck reaches operating tempature, and it is worse on hot days.
I have read on here something about cleaning the MAP sensor. I see in the bible that it is an electrical componet, but where is it? Do you think that this might be the problem?
I need to pull my tractor up the mountain on Saturday, and I am almost afraid too. Any help would be greatly appreciated.
Thanks,
Nate
Old Aug 14, 2008 | 06:37 PM
dcaddi2's Avatar
dcaddi2
Thanks,
Nate
Welcome to the FTE!
Do you have an OBDII code reader? If you don't pull up to a parts store , and ask them to check if you have any DTCs. Even with your engine light not on, you could have some codes, and that would help to solve your problem....
Old Aug 14, 2008 | 09:15 PM
msgtg's Avatar
msgtg
Nate, we need a little more info...
Are you the original owner? How long has this been happening? When was your last fuel filter change?
Joe
Old Aug 15, 2008 | 05:02 AM
25-06shooter
We bought the truck in Sept. of '06 with 27,000 miles on it. No hint of any trouble until somewhere around 50K. Since then it has been back to the dealer 3 times. They have replaced the EGR, 2 computer updates, and replaced 2 injectors. The last time was back at about 75K.
I keep the oil changed every 5K with Rotella 15-40, and I just changed both fuel filters 2 weeks ago for the second time.
Thanks for the help,
Nate
Old Aug 17, 2008 | 08:40 AM
25-06shooter
First off, I really appreciate the help.
Hopefully you are using Motorcraft, International, or Racor filters - it is very important
I normally use Motercraft oil filters, but when I changed the fuel filters I used Fram. This may be a stupid question, but I have never had to worry about using stock filters on any other vehicle I have owned. Will it change the pressure enough to cause problems?
Friday evening I hooked the EGR back up and re-installed the butterfly valve. When I pulled off the elbow, it was soaked with oil. Not sure why, another problem?
Anyway, I hooked up to the tractor (around 10k #'s) and took off up the mountain in tow/haul mode. 150 miles later, I am back home and it never once bobbled. Ran like a top, pulled like a dream.
I guess the next test is to drive it around town for a day and see what happens.
Thanks again for the help,
Nate
Old Aug 17, 2008 | 09:03 AM
dcaddi2's Avatar
dcaddi2
Nate
The 6.0 diesels are very picky vehicles, especially oil, and filters - wise. You can do some research on this forum, and you'll be surprised how many issues are there because of filters.
Old Aug 17, 2008 | 09:22 AM
brickie's Avatar
brickie
Rough idle ,surging and stalling sounds like clasic ICP problems to me.Un hook the ICP sensor and see if the surging stops.
Old Aug 17, 2008 | 01:14 PM
bismic's Avatar
bismic
Nate
Here is some info on filters (not saying it is your issue, but it is important):
<TABLE style="WIDTH: 607pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=809 border=0 x:str><COLGROUP><COL style="WIDTH: 607pt; mso-width-source: userset; mso-width-alt: 29586" width=809><TBODY><TR style="HEIGHT: 25.5pt" height=34><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 607pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 25.5pt; BACKGROUND-COLOR: transparent" width=809 height=34>Use ONLY OEM and OEM style oil filters (which are made by RACOR). Lots of threads on this subject AND info in the Tech Folder.</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 607pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=809 height=17>http://www.trademotion.com/pages/index.cfm?action=viewPage&siteid=214083&pageid=101 48</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 607pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=809 height=17>http://www.forddoctorsdts.com/articles/article-06-04.php</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl26 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 607pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: yellow" width=809 height=17>http://www.youtube.com/watch?v=Lm3mOhQRqr4</TD></TR></TBODY></TABLE>
