Modular V10 (6.8l)
Header bolts
Old Aug 14, 2008 | 10:52 AM
Heavy_Metal's Avatar
Heavy_Metal
Header bolts
I was looking to find out, since I did my header install with the original studs (mistake), what the size bolts I would need to get for them so I can buy them before I tear everything apart. Anyone know the thread size/spacing and length? Thanks.
Old Aug 14, 2008 | 01:23 PM
dkf's Avatar
dkf
M8x1.25 is the thread size. The length depends on how thick your header flanges are. The studs that came out of my trucks threaded in 5/8" into the head. Say 3/4" in the head plus 3/8" for the flange so thats 1 1/8" long. If your going to use a lock washer or star washer you have to plan for that. The threads should be tapped into the head farther than 3/4" but that may vary. I know the studs that Krewat pulled from his 01' were made different than the studs that came out of my 04'.
I have 1" long hex head bolts with star washers holding my Thorley Headers on.
Old Aug 15, 2008 | 03:54 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
I used the depth gauge on my dial caliper to figure the depth, added the flange, and GASKET(!), and a washer. And then subtracted about 1/8" - so yea, 3/4" is about the right depth of the hole.
I'd check the depth on ALL the holes - who knows what the factory did (or didn't do).
Old Aug 15, 2008 | 04:16 PM
Heavy_Metal
I figured I'd measure, just wanted to get a heads up on the situation.
Old Aug 18, 2008 | 08:27 PM
Jax 99's Avatar
Jax 99
H-M,
when you got your headers on where did you attach the egr tube that was on the exhaust manifold?
also did you notice any difference in torque or mpg's?
ive been thinking about getting the ebay headers before i install the used motor ive got,
but i have a 99 F350 with the egr & want to keep everything.
thanx
Old Aug 19, 2008 | 08:36 AM
dkf's Avatar
dkf
Originally Posted by Jax 99
H-M,
thanx
You can get the Ebay headers, you just have to get an EGR bung welded on. May want to look at the Ford Motorsport or JBA headers. Both are more expensive than the Ebay headers however you can get them with or without the EGR bung.
Old Aug 19, 2008 | 02:34 PM
Heavy_Metal
I drilled a hole in the 3rd primary tube from the front and welded a bung to it. My new set of headers are not going to have EGR on them. I'm removing the system and switching off EGR with my diablo tuner.
It took a little "massaging" of the egr tube but it worked.
MPG= small increase, think it was in conjunction with the exhaust setup and possibly the high flow converter.
TQ= significant increase, less shifting out of OD when towing and feels more responsive.
Old Aug 22, 2008 | 07:09 PM
Jax 99's Avatar
Jax 99
H M , thanx i have read your other post & i think ill keep t stock for the time being or atleast til i can get the motorsport headers.
Old Aug 28, 2008 | 06:14 PM
AllAboutDaZ's Avatar
AllAboutDaZ
seems seems like i am going to have to order me a set
might as well
outlw
Sep 27, 2012 08:58 PM
F-250 restorer
15
Nov 4, 2009 07:05 AM
scottlane
Jun 18, 2009 08:33 AM
low54
20
May 10, 2009 09:07 PM
Customcab
Dec 15, 2007 07:47 PM
