On my 2002 F-250 super duty, every once in a while when I start it the windows and radio will not work-- let run from a 1 min to 5 min and they come back on?????? I am guessing that it is some type of relay but don't know which one it is--- any help will much appreciated.. thanks NCFord4X4
This is about the 5th time this topic has came up with no answer. it happens to me too every once in a while. mine seems to be with the door or something. when this happens to me i can open and shut the door again and the windows and radio start to work again. i'm wondering if we need to spray something with some good ol wd 40.
There is an accessory delay relay that powers the radio and p/w switches. The relay keeps power to these circuits until the door is opened after the key is turned off. The door latch switch would deactivate this relay when the door is opened. I believe the relay is timed by GEM to keep it engaged for a length of time before the door is opened. The problem could be in any of these three areas. Just my thoughts. I haven't seen the diagrams for all these circuits.
This is where I would start as well. Switch the accessory delay relay with one next to it. Like the one touch window power down relay. If problem still persist, it is most likely in the gem module. That little box controls quite a bit and creates some really weird things when it starts to go out.
I will add that there seems to be an issue with a decent amount of '02's and their GEM. I am not sure why, but it seems to me like the likely culprit in this case.
U2?
I have that happen to me
drives me nuts
i thought it may have something to do with getting a remote-start system installed earlier this year
any ideas?
I also have remote start and the same problem but its getting worse... Much worse. Dealer has no clue. Any of you other guys have remote start as well?
I have 00 F350 that had this prob. the fuse was loose in the fuse block under the dash.
Took me awhile to track it down , try to wiggle it and see if it cuts out.
