Another Engine Failure Thread....
I was going to post on this also, but Pop beat me to it. I used Ti valves, intake and exhaust in the below pictured car. At the cost of those valves 25 years ago, I damn sure would not want to pay for a set of pistons. Not many people would.
What I am thinking as of right now, that the pistons got hot at the top so many times, it went through a lot of heat cycles that weakened right were the skirts are(crown is hot, skirts are not as hot). Then since when the truck is tuned, the timing is increased, thus causing more pressure on the piston. This over and over again kept weakening and weakening the piston then it decided it had enough and decided to just give. That's my best explanation right now. The casting failure is also in for a suspect, but for right now, I am going with heat cycles causing the failure. I guess that's what happens when you buy a vehicle with 4 previous owners. FWIW all the pistons are cracked, none of them look serious, as if causing a failure itself, but are still cracked.
Kinda on a time line crunch since winter is approaching. Driving my car in the winter around here is not going to be ideal and I really do not want to, but If I have to Ill have to. Like Jeremy said these posts are not fun, the next part is fun, but makes my wallet a lot lighter than it already is.
Now, here is something I can't understand. Even though I see the failure, I can't see what the noise was. Those pieces appear(as of right now) to have fallen right off, went into the pan. A lot of you know what the noise was(almost like a valve train noise/dead miss sound), but I can't understand, someone who understands please explain it to me, what was causing that noise. Just piston slap like pop was saying? I'm still confused, the rod is on my bench, and the connecting pin is still in the piston along with both compression rings and oil ring. The other piston I can see appears to have the same failure, so I am assuming as of right now its the same. Any ideas?
Me to, fortunately the only wrench that has touched my truck was for filter changes and a few mods.
I am going to post some pictures of the rod bearings also, seems to look awkward to me on the #7hole, odd wear patterns. Looks like I might have dodged a bullet, but I am still pissed about the whole thing.
Lesson learned: This will be the last time I buy a 4 previous owner truck as a DD. This truck was abused before I got it, and I got the end results. I will also being researching much more before I buy anything over the price of $100. Glad I learned this lesson before I bought my car, since that purchase was thought out very well before I did anything. Do I regret my decisions, nope, learned a valuable lesson first hand, the best way.
There isn't any reason there HAS to be block damage if just the skirts came apart. So long as the wrist pins remained in place, and didn't gouge the cylinder walls, there's a good chance that he can power hone them ten over, use new Mahle's (good call Kris), rings, bearings, and be ready for another 300,000+.
Pop
You can find a rebuild kit that has Mahles, and everything you need to put it back together. Shop around.
