Header Leaks
Old Aug 13, 2008 | 07:58 PM
Guttshott's Avatar
Guttshott
Header Leaks
I just put a new set of hedman headers on my '93 302...The drivers side will not stop leaking....I changed gaskets got double gaskets on it now and it wont stop...They are only regular gaskets...Please Help!!!...The noise is driving me crazy!!
Old Aug 20, 2008 | 03:44 PM
jerg_064's Avatar
jerg_064
was the gaskets changed on the collectors and heads.
Also with one of my header leaks i had for a while there was white ash or something around the ex port that had the gasket leak. If you have something similar maybe try checking out the surface on that area or on the headers to see if they have the right texture/form to seal properly.
Old Aug 20, 2008 | 04:51 PM
Guttshott's Avatar
Guttshott
I got it to seal at the head but now i find the there is a leak where the tubes are welded to the collector!
Old Aug 20, 2008 | 05:05 PM
jerg_064's Avatar
jerg_064
right on for the seal at the head, hmm, I bet a lil brazing should fix up the welds. I heard a wire hanger and 12v battery is an easy and cheap fix. Not sure how to do it though.
Old Aug 20, 2008 | 05:14 PM
danr1's Avatar
danr1
I'd take it off and return it for a replacement, the bolt flange was/is likely bent giving you so much trouble sealing it to the head.
You shouldn't have to use more then one gasket to install a new set of header. If the flange is flat and true there would be no reason to.
Now you find the welds at the collector are sh**.
Take em back and make them give you a new set, take a good straight edge with you, take em out of the box to check them right there in the auto parts before you accept them. Be sure to go over all the welds looking for gaps or cracks while your at it.
Old Aug 20, 2008 | 07:25 PM
jerg_064's Avatar
jerg_064
Yea, that's definitely a better idea than mine.
Old Aug 20, 2008 | 07:40 PM
danr1's Avatar
danr1
Well no, your idea isn't a terrible one, it could work just fine depending on where exactly it leaks. If it could be repaired without removing it it may be worth it.
Myself with a new one? One that already was a pain to seal? I'd be more likely to just remove it rather then weld or braze a bad spot for them. That would also depend on the factory finish, just plain primered steel? yea if not real bad I may just fix it in place. The ceramic coated or stainless would have to go back if it where me without a second thought.
I would also think any attempt to repair it weld/braze would void any warranty regardless of finish or material so that is something else to consider as well.
An older set? sure braze the heck out of em!
Brazing rod is cheap, watched a guy try and fix a hole in a tractor rim with a coat hanger, with no flux he couldn't get it to stick to save his A**! lol
I ran down and got him a real rod so he could get the wheel back on.
Old Aug 20, 2008 | 08:14 PM
95F350XL's Avatar
95F350XL
Sometimes the aftermarket headers have bigger openings in them vs the stock ones, if you get a good set of gaskets you shouldnt have a prob. I use these, sell at autozone/pepboys. These are Mr Gasket ultra seals if i remember right.
Old Aug 21, 2008 | 03:03 AM
unleashed's Avatar
unleashed
u might look for the "crushable copper" gaskets as well.they cost a lil more,but seal very well to irregular surfaces.
Old Sep 15, 2008 | 01:25 PM
Guttshott's Avatar
Guttshott
Thanks for all the tips...I took it off and welded it shut!...The one pipe going into the collecter wasnt even welded...It was welded from the inside and it looked as tho it was to short and was leaking where it goes into the collector..So i just filled it up with a welding rod...Ah well a lesson learned!!
